Thread: Rate of chlorine loss in a covered pool verses an uncovered pool
    May 2015
    minneapolis minnesota
    9
    I know there is a difference, but can anyone quantify it for me? It seems like when I cover the pool the chlorine lasts a lot longer.
    Thanks in advance
    30,000 gallon in-ground; cartridge filter; Hayward Super Pump; vinyl liner
    Jun 2014
    15,008
    Re: Rate of chlorine loss in a covered pool verses an uncovered pool
    Here was a previous discussion on that topic: What effect does having a cover have?
    Mar 2007
    San Rafael, CA USA
    12,082
    The answer is temperature dependent because while the loss from sunlight depends only on the amount of sunlight (at a given FC and CYA level), the losses other than from sunlight are a function of temperature. For example, in my warm pool at 88F with a mostly opaque pool cover, if it's on all the time the loss is around 0.7 ppm FC. Without a cover the loss would be roughly 2 ppm FC. However, if I had a lower water temperature the loss might be less than 0.7 ppm FC so an even bigger difference.
    Ironically, the chlorine losses other than from sunlight are mostly chlorine oxidizing the cover, assuming you have a clean pool and filter. There is also some lost from outgassing when the cover is off, but not that much.
