Results 1 to 18 of 18
Thread: Brown dust
    May 2015
    Winfield Alabama
    31
    Brown dust
    On the bottom of my pool has a brownish dust on it, when I vacuum or get close to the vacuum it disappears. After I let the water filter it settles back. What could this be?
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,112
    Re: Brown dust
    what kind of filter do you have? it might be DE if you have that kind.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    May 2015
    Winfield Alabama
    31
    Re: Brown dust
    I have a sand filter. After I used floc is when this happened.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,112
    Re: Brown dust
    That is what floc is supposed to do, I think. We don't use it here so I'm not real sure...
    Just move super slow when you get near it.
    May 2015
    Winfield Alabama
    31
    Re: Brown dust
    Its confusing I vacuumed all of it up besides the same few spots, because they disappear. I have a brush vac but also one with the wheels. I just added 2lbs of shock and 2 3' chlorine tabs.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,112
    Re: Brown dust
    We have a different method of pool care here. No 'shock' No 'pucks' Just a few simple things from the grocery and hardware store. Never go to a pool $tore again. OR at least, very, very rarely.
    May 2015
    Winfield Alabama
    31
    Re: Brown dust
    These products came from Wal-Mart. I dont do the pool store thing.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,112
    Brown dust
    Our stuff come from the Laundry aisle.
    May 2015
    Winfield Alabama
    31
    Brown dust
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,058
    Re: Brown dust
    Dust bunnies on the floor that disappear when you approach them with a vacuum or brush is classic algae behavior. It's mostly dead stuff. You need to kill all of it.
    It sounds like you're not maintaining adequate chlorine for your stabilizer level. Can you post test results? And how are you chlorinating?
    May 2015
    Winfield Alabama
    31
    Re: Brown dust
    I use 'pucks' for right now. I just added 2lbs of shock and 2 3' chlorine 'pucks'
    Richard320's Avatar
    Jan 2010
    19,058
    Re: Brown dust
    Quote Originally Posted by Hubbert21 View Post
    The pucks raise the CYA level, which may or may not be a good thing. The "shock" could be adding more; there are at least three different powders that are called shock and two of them do. They also mess with the pH. In brief, you might be making a bad situation worse. Anyway.... the solution remains the same as before I can't improve on the answer you got before.
    May 2015
    Winfield Alabama
    31
    Re: Brown dust
    I have the Aqua Chem 6 way test strips for now. (I know better test kit) but anyway my results are
    total hardness-100
    total chlorine-0
    free chlorine-0
    pH-7.2
    total alkalinity-120
    stabilizer-50
    Richard320's Avatar
    Jan 2010
    19,058
    Re: Brown dust
    total hardness-100
    total chlorine-0
    free chlorine-0
    pH-7.2
    stabilizer-50
    If you believe those strips, your CYA is 50 so your minimum FC should never dip below 4 and you should target more like 7 every day. Your CYA will be slightly higher when those pucks are done dissolving, so 8 FC might not be a bad target for you. Pool School - Chlorine / CYA Chart
    May 2015
    Winfield Alabama
    31
    Re: Brown dust
    So do you know what I need to add? The water is blue just slightly cloudy.
    Jul 2014
    NJ
    123
    Re: Brown dust
    Not to step on Richard's toes here (since I would listen to him like gospel) but you need to add chlorine (preferably bleach or sodium hypochlronite).
    You can use the Pool Math link on top to calculate how much you need to add. Plug in the numbers for number of gallons of water in your pool, FC = 0, ph = 7.2, etc. For your target for FC you want 8. Then mouse over to the right hand section and specify what kind of chlorine you plan to put in. The calculate will then tell you how much to add if you put your mouse over the appropriate metric.
    20x40 L-shape 35k gallons, Pentair FNS 60 SQFT DE Filter, Pentair Multi-port Valve, Hayward Super Pump w/1 glorious HP, Vinyl Liner, Dolphin Z5, TF-100 w/Speed Stir
    Casey's Avatar
    SW PA
    10,457
    Re: Brown dust
    Desperate situations like yours need to be addressed acurrately and swiftly. You can not do either at this point in time without a test kit. You are right in the middle of a bloom and unless you take your pool by the rafts and kick this bloom out of your pool, you're going to watch it take over.
    You need a TF100.
    Post accurate test results.
    Bleach.
    Pool School links on how to defeat algae.
    You may not want to hear it but this is what you need to clear your pool. Well be here when you decide to do it the right way.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,513
    Re: Brown dust
    As Richard said, read the Chlorine CYA Chart to determine what your chlorine level is for your CYA level. Never let the chlorine drop below the minimum level for your CYA level or algae will grow.
    Here are some of my fave Pool School articles in case you missed any of them.
    TFPC for Beginners
    ABC's of Pool Water Chemistry
    Here are the Recommended Levels for your pool.
    Here are the Recommended Pool Chemicals and how to add them.
    Use PoolMath to figure out how much to add.
