Results 1 to 9 of 9
Thread: Pump overheats ever since electrician put something else on that outlet
    Jul 2014
    Evansville, IN
    72
    They are coming to fix it, but can I shower it with cold water without doing damage? Thanks
    16 x 32 Sport Pool; Hayward Series Sand Filter S244T
    15,000 Gallons, In Ground with New Vinyl Liner
    Pool approx. Five Years Old. Live in KY
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: Pump overheats ever since electrician put something else on that outlet
    Probably not wise to do. I would just turn it off until they can fix it or turn off what ever they connected on the circuit. BTW, what did they put on the circuit and can the circuit handle the amperage of both devices?
    Mark
    Jul 2014
    Evansville, IN
    72
    They put three sump pumps under my house that draw power all the time; granted not as much as when they occasionally are pumping. I also have my pool light and some outdoor lights on that circuit. Never had a problem until they did that.
    Jun 2014
    15,096
    I was under the impression that a pool should be on its own dedicated GFCI circuit. More than one reason for that I suppose. But you would think an electrician would know that as well unless it was too much work to try and run a new line for your sump pumps. Just my guess. Maybe he did the math and figured it "should" be okay.
    Jul 2014
    Evansville, IN
    72
    Lol. Probably so. I unplugged the sump pumps and so far so good.
    Jul 2014
    Evansville, IN
    72
    I unplugged everything and it still overheats- even at night. I took it apart and everything was clean. Any thoughts? Thanks
    22,548
    I think them adding the pumps and the overheating is a coincidence. Adding load to a circuit wouldn't cause the pump to overheat. If it did anything it would have caused the breaker to trip.
    Pump motors run hot to begin with. How hot is it getting? Do you have something that you can actually test the temp with? If not, can you force yourself to hold your hand on it for 8 seconds?
    Apr 2015
    South Central PA
    297
    Not only should the pool have it's own dedicated circuit, I don't think you want the sump pumps sharing a circuit with anything either...when the sump pumps are needed, you don't want to have anything interfere with their ability to do their job, such as overloading a circuit and then getting water in your basement....
    20000 gallon vinyl liner in ground pool
    16' X 34' rectangular diving pool
    Hayward Pro Grid DE Filter
    Hayward 1 hp Super Pump
    TF-100 Test Kit Stenner 45MPHP10
    Jul 2014
    Evansville, IN
    72
    Quote Originally Posted by Bama Rambler View Post
    No, I can't even put my hand near it because of the radiant heat. No telling what the temperature is. I leave it off during the day and turn it on at night. It does a little better at night.
