Results 1 to 8 of 8
Thread: Local Copy of PoolMath
    May 2015
    Demorest, GA
    11
    It states I can make a local copy of PoolMath and not have an internet connection, could someone tell me how to do so?
    20,000 gal. vinyl chlorinated pool
    Cartridge filter
    pinguy's Avatar
    May 2015
    Pennsylvania
    516
    Re: Local Copy of PoolMath
    File > Save AS
    Open the HTML file in a browser.
    Helpful Links: Pool Chemistry 101 - Recommended Levels - Recommended Chemicals - FC/CYA Chart - SLAM Instructions - Pool Math
    Test Kits:
    TF-100 - Taylor K2006 - SpeedStir Upgrade - Taylor K-1766 Salt Test
    My Pool:
    28k IG built May 2015 - Autopilot SWG - Pentair VS Pump/DE Filter/Heat Pump
    38,475
    What browser are you using?
    You should be able to right-click on the page off of any links and pick something like "Save Page As ..."
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Learn something every day.
    You can also install PoolPal on your Android phone. Probably iPhone as well.
    25000-gallon semi-public IG concrete/plaster pool, Triton II sand filter
    750-gallon semi-public IG concrete/plaster spa, cartridge filter
    Volunteer pool caretaker for my condominium complex
    May 2015
    Demorest, GA
    11
    Thanks!
    Cartridge filter
    gtemkin's Avatar
    Jun 2008
    Seattle, WA
    738
    Quote Originally Posted by TomBorg View Post
    Since it was mentioned, does the Pool Pal app have all the features of PoolMath? I've tried a few pool apps and found most are a very big disappointment when compared with PoolMath. The preview information for the iPhone version of Pool Pal doesn't say what it calculates, or what parameters can be pre-set. Can it pre-set all the same chemical concentrations or predict effects of additions? Could you list them please?
    21K gal 16' x 40' in-ground pool built 1959, old school with Jacuzzi bronze pump, American Products 24" Sand Filter & Americana Multiport valve, Jandy Lite2 millivolt heater, Coverstar cover, and classic Kreepy Krauly.
    Jun 2011
    Carlsbad, NM
    172
    Pool Pal has water temp, FC, pH, TA, CH, CYA. It calculates CSI, LSI. Tracks pressure, backwashing, filter clean. The configuration screen has everything you need as far as chemical type and concentration. Disclaimer- this is the android version.
    36' x 18' 20k in ground, Finest Finish grey plaster, Pentair Tagelus 100D sand filter, Hayward Northstar 2hp pump, Jandy LRZ125EN heater, spill over spa, iaqualink controlled automation, Stenner chlorination, natural rock and flagstone coping, 1" glass mosaic waterline tile, SR Smith Vortex slide.
