Thread: Test kit
    Jun 2015
    Coatesville PA
    1
    Test kit
    Is it important to get a new test kit each year. My test kit is a year old. Is it still good?
    27 ft round above ground pool.
    5 years old.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Test kit
    Welcome to TFP!
    If you stored it in a dark, climate-controlled location, your kit should get you through a 2nd swim season. It would still be a good idea to check your reagents for discoloration. If none is present, you should be good to go.
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: Test kit
    If you kept it inside all winter, it should be OK. Most of the reagents in the TF-100 and K-2006 are good for a couple of seasons. Just replace what you are low on before you run out!
