Does anyone have an AquaTrol and run their filter pump 24/7? How would this work? Would the aquatrol then be running 24/7 as well? Can you run them seperate? Just a little confused before I buy one.
You can run the pump 24/7, but that's really overkill. If you do that, you would just adjust the swg output lower so it makes the correct amount of chlorine for your pool. I run my pump 6 hrs a day with my swg set at 80-85%.
