Thread: Pool Water Chemistry links still broken
    Mar 2007
    San Rafael, CA USA
    12,082
    There are many posts I have written on this forum that link back to some Deep End threads, most notably Pool Water Chemistry, but many of these links are broken. As I stumble upon some posts with such broken links, I am fixing them, but a global change/substitution would fix them much faster. For example, change the following link (that is broken)
    http://www.troublefreepools.com/view...hp?p=4367#4367
    into
    http://www.troublefreepool.com/threa...ull=1#post4122
    that is the intended post. If you can figure out all such broken links and fix them, that would be great, but I understand that may not be easily doable.
    May 2015
    Chicago, IL
    508
    Re: Pool Water Chemistry links still broken
    This is something we are working on addressing. There was something in place before to redirect the links, but that has become a issue. I am still working on it though.
    Mar 2007
    San Rafael, CA USA
    12,082
    Thanks. It's cropping up in all sorts of places on the forum and I'm correcting these when I can. This post had the following two links:
    http://www.troublefreepool.com/ever-...ool-t1235.html
    http://www.troublefreepool.com/saltw...her-t1624.html
    that I changed to
    http://www.troublefreepool.com/threa...ke-a-SWCG-pool
    http://www.troublefreepool.com/threa...-s-the-Weather
    Mar 2007
    San Rafael, CA USA
    12,082
    So other people are noticing the many, many, many broken links and I responded in this post with how I have been recovering them manually in my posts as they come up during my searches.
    This needs to get fixed AUTOMATICALLY and it should never have become broken during the server move in the first place.
    May 2015
    Chicago, IL
    508
    Yes it would become broken during any server move, if the right things are not done. I had them fixed, but Lee should be able to fix it.
