Results 1 to 7 of 7
Thread: Variable return jet
    Oct 2014
    Bay Area, California
    146
    Variable return jet
    Seems like an almost necessity with a variable speed pump.
    Approx 15,000 gallon gunite pool, fiberglass finish. Hayward SP2302VSP, compools solar controller, 6 4x10 "Sealed Air" brand solar panels, Clean and Clear 520 cartridge filter
    May 2015
    Odense SŲ
    28
    Re: Variable return jet
    It looks bizar in some way
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Never seen that, what is the story?
    Oct 2014
    146
    Quote Originally Posted by pooldv View Post
    The jet changes size, so it's small when your pump is running at a low RPM. The smaller orifice will provide a more powerful stream promoting better circulation and agitation
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    38,274
    I actually bought a set of these when I saw a good deal ... But have not gotten around to installing them.
    Supposed to just add a little more velocity to the return jet when at lower speeds.
    Oct 2014
    146
    I got some of these. They seem to work as they should and always seem to have a powerful stream coming out of them.
