Results 1 to 8 of 8
Thread: Thank TFP!!!
    k8twhite's Avatar
    Mar 2015
    Lewiston/Idaho
    3
    Wink Thank TFP!!!
    I am happy that I finally have the hang of this and I am no longer dumping money down the drain/backwash hose! This is the difference one week made in my pool using the BBB method.
    -20,000
    -IG
    -vinyl
    -sand
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: Thank TFP!!!
    Gorgeous! You did the hard work, we just helped to guide you.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    northrn's Avatar
    May 2014
    Cincinnati, OH
    532
    Re: Thank TFP!!!
    that looks fabulous, k8t!!! congratulations to you on a job very well done!
    27' AG 18K Gallons ~ Cartridge Filter ~ Pentair 1.5 HP Pump
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Re: Thank TFP!!!
    Wow! Nice pool!
    k8twhite's Avatar
    Mar 2015
    Lewiston/Idaho
    3
    Re: Thank TFP!!!
    Thanks guys!
    -20,000
    -IG
    -vinyl
    -sand
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Thank TFP!!!
    We couldn't have helped clear your pool without you! Seriously, nice job!
    Jul 2012
    Dallas, TX
    179
    Re: Thank TFP!!!
    k8twhite
    Wow, there's nothing like a "before" and "after" picture testimonial of pool success.
    This site has helped me out a lot as well. I don't have amazing pics like that but since I switched to bleach dosing last summer, it's been smooth sailing with my pool.
    - Pool Type: 15k Gal Gunite IG non-SWG / Built 1988
    - Pump: Pentair Challenger / Sweep Pump: Letro Model LA01N .75HP Single-speed / 6 hrs-day (1 turnover)
    - D.E. Filter: OEM: Nautilus (Pentair) #NS 36 / 36 Sq Ft / D.E. Charge: 3.6 Lb
    - Pentair 4-wheel Sweep LL505G - Booster Pump runs ~2 hrs/day
    Steve-in-VA's Avatar
    May 2015
    Smithfield/Virginia
    199
    Re: Thank TFP!!!
    Looks great...hoping mine looks like that by the weekend. Good job!
    21,200 gallon/ 30' vinyl round above ground pool/ 200# hayward sand filter/1.5 hp hayward pump (70gl/m) /
    /self installed pool about 3 years ago - Smithfield, VA- Pool filled with well water -TF100 kit
