Results 1 to 9 of 9
Thread: TA Testing
    May 2015
    River Falls, WI
    124
    TA Testing
    When doing the drop test for TA there’s usually a slight color change and then an obvious color change with the next drop. Which drop should I be using for my readings?
    ~19k Gal, IG Vinyl, Hayward SP2607X10 1hp pump, Hayward S200 Sand Filter, built in ‘70’s, has 8’ deep end with diving board, 1 skimmer, 1 return, 1 low hole, Polaris booster pump PB4-60, old Polaris robot not sure model, Rheem P-M266A-EN-C 266,000 BTU heater, solar cover, Taylor K-2006 test kit, Speedstir
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: TA Testing
    Once you are sure it stops changing completely, be certain with one more drop, and if that final one doesn't change it any more, don't count it. Always push your endpoint to the end where there is no more color change.
    Essential Links:
    May 2015
    River Falls, WI
    124
    Re: TA Testing
    Thanks!
    May 2015
    River Falls, WI
    124
    Lowering TA
    How long does it usually take to get a sense of the new PH & TA readings after dosing with MA, or is it pretty much right away?
    I tested about a half an hour afterwards and PH dropped as expected. My TA, on the other hand, had no movement. I'm aerating now to bring PH back up and in a few days I can try again. I'm just wondering if my test only about a half an hour into the dose isn't providing a true accurate picture of TA...
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: Lowering TA
    It is a process. I have been working on this since finishing my SLAM. I add enough MA to drop PH to 7 and then aerate 24-48 hours until PH comes back up to 7.5-8.2 ranges and do it again. I find if I do it every 24 hours it goes faster.
    Results after SLAM
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Lowering TA
    A half hour is usually good for pH but my personal preference is one hour for acid mixing. You should not expect to see a lot of TA movement unless you make pretty significant changes to the pH. Larger TA movements happen over time. You can see any TA shift about as soon as you can pH after an addition and mixing, but big shifts have to be done over days, or weeks usually. Making small shifts over time that is.
    Essential Links:
    May 2015
    River Falls, WI
    124
    Re: Lowering TA
    How long should swimmers wait until entering the pool after a MA dose? I suppose it matters on the quantity but lets say like 40oz...
    Mod Squad pooldv's Avatar
    DFW, TX
    24,491
    Re: Lowering TA
    Added in front of a return with the pump running I usually wait about 15 minutes.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Lowering TA
    Something to keep in mind about the relationship between pH and TA...
    TA is a buffer for pH - a fine-tuning if you will. pH is like a channel selector that displays the desired channel. TA is a fine-tuning dial that brings the selected channel into sharper focus. The "right" TA for your pool is that level where your pH stays relatively stable.
