In pool math enter 0 in the first box for FC and enter 2 for goal. Then add how much chlorine it says.
In the future don't add chlorine and MA at the same time. It probably p did not hurt anything, but space them 30 mins apart.
Thats what I did.. I added 50oz of 10% Chlorine. Got ya on the adding chlorine and MA apart.
I'm scooping and scooping.. just cant see the bottom.. but still getting worms.. mostly all by the main drain.Scoop, scoop and scoop. If there is stuff down there it will consume your Chlorine in no time. Get as much out as you can.
For the acid, what did Pool Math tell you to add? Don't go dumping the whole thing when you add stuff, you need more precise amounts, especially with acid and CYA.
What strength is the acid?
Pool math said to add 66oz. of MA. Strength is 31.45%
When you say don't dump the whole amount.. do you mean measure out the whole amount and dump little bits at a time, or dump some and retest?
