Thread: Dualpro11 Laser 192 pool filter
    May 2015
    windsor ontario
    1
    Hi
    I have the above mentioned pool filter and there is no backwash setting. It has a filter, whirlpool, winterize, drain and rinse setting ...which setting do i use to backwash the filter I would appreciate any info
    Thanks
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: Dualpro11 Laser 192 pool filter
    Welcome to TFP! I am sure someone will have an answer for you soon.
    If this is a cartrige filter you cannot back wash, it it is a sand filter, I have no idea.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    There should be seven positions:
    1. FILTER
    2. BACKWASH
    3. DRAIN
    4. WHIRLPOOL
    5. WINTERIZE
    6. RINSE
    7. TEST
