Thread: gsanlocke - signature help
    May 2015
    Ontario, Ca.
    1
    Hello I am a 1st timer here is the paragraph above what they call a signature ? I have tried 3 x's and I can't get it to accept it ?
    30,419
    Re: gsanlocke - signature help
    Welcome to the forum.
    Click on "settings" in the upper right corner. Then you can edit your signature by selecting it in a box that will open on the left.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    You may have to trim down the length, they are limited in size, I know I had to trim mine after the last equipment change to get it to fit (lines were too long)
    May 2015
    Chicago, IL
    508
    Here is what it can contain:
    Up to five standard height lines of information about you, your pool and equipment, and most anything else you think is important to tell people every time. Please be specific. The best information to include is the size of your pool in both feet and gallons, the kind of pool surface (vinyl, plaster, fiberglass, pebble), what kind of filter you have (sand, DE, cartridge), and if you have a SWG. Anything else you feel like mentioning is great as long as it fits in five lines. Information about your pool helps us answer your questions and helps people reading your posts understand the context.
    If you are still having trouble after following those guidelines, PM me exactly what it is you are trying to add as your signature, and I can look into what the issue may be.
