Page 1 of 3 123 LastLast
Results 1 to 20 of 43
Thread: Still cloudy water
    cfclay's Avatar
    Apr 2010
    Little Rock, AR
    204
    Still cloudy water
    I opened pool ten days ago and my water has been balanced for four days pretty well:
    FC: 3
    CC: .5
    PH: 7.5
    CYA: 40
    TA: 90
    What am I missing team?
    Intex 22' x 52" - Intex Krystal Clear Sand Filter Pump - flow rate: 2,150 gal per hour
    TFTest Kits TF-100
    Waiting to stop relocating until I build my dream pool!
    30,432
    Re: Still cloudy water
    We need more info. What was it like four days ago? Did you SLAM?
    What is that on the bottom of the pool opposite the camera?......debris or a liner stain?
    cfclay's Avatar
    Apr 2010
    Little Rock, AR
    204
    Thanks for responding. As I read the SLAM procedures- I'm looking for this:
    1. CC is 0.5 or lower;
    2. You pass an OCLT (ie overnight FC loss test shows a loss of 1.0 ppm or less);
    3. And the water is clear.
    I didn't do the SLAM process at first because it seemed like it took a several days to get the water balanced in terms of PH, TA, and CYA. I just added enough chlorine to get me to 3 ppm. I would say that I am just now in the last 48 hours reaching "B". There were some days about 5, 6 days ago were it seemed like all Chlorine was gone the next day. We had about probably 4-6 inches of rain in a flash flood and I think that was another day that I lost all chorine on the reading. I think it looked like this 4 days ago really.
    In the picture- that's not a stain but some debris not yet vaccuum. I brushed and vaccumed several times- this is just the last little bit left
    TFTest Kits TF-100
    30,432
    Get the debris out of your pool first and then SLAM it. It won't take long and your water will sparkle.
    cfclay's Avatar
    Apr 2010
    Little Rock, AR
    204
    Just to be clear (pardon the pun), I would add chlorine to bring it up to shock level- that's 16 ppm for a CYA of 40. Then keep doing this until there is less than 1 ppm million loss in Free Chlorine? Keep adding to that shock level?
    TFTest Kits TF-100
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,870
    Yes keep it at that shock level until you lose less than 1ppm overnight. The overnight test eliminates the sun as a factor in consuming the chlorine. So if you're losing more than 1ppm overnight you know it is organics (algae) consuming the chlorine and not the sun. While at slam level make sure to keep brushing and get all the debris out.
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    30,432
    Quote Originally Posted by cfclay View Post
    Yes. There is a SLAM article in Pool School to help you.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Here is the process for SLAMing Your Pool
    cfclay's Avatar
    Apr 2010
    Little Rock, AR
    204
    Still cloudy water
    Thanks for sending that link folks. I'm five years into my troublefreepool.com forum membership; so I have definitely refered to that link. However if I may comment- finding that particular link does seem quite difficult when only using the Tapatalk IOS app.
    TFTest Kits TF-100
    DFW, TX
    24,514
    There have been issues with broken links since the server upgrade on Friday. They are working on them.
    http://www.troublefreepool.com/conte...tain-shockingl
    cfclay's Avatar
    Apr 2010
    Little Rock, AR
    204
    So Saturday I added enough chlorine to get to 16 ppm. On Sunday morning I was at 13. I added bleach to get to 16 ppm. At 9 pm I am at 10 ppm. Are these results typical?
    TFTest Kits TF-100
    DFW, TX
    24,514
    Yes, it is not uncommon to use lots of bleach early in a SLAM. If you can it is helpful to test and add bleach every 2-3 hours at first, then 2-3 times per day after chlorine level is holding better.
    cfclay's Avatar
    Apr 2010
    Little Rock, AR
    204
    Quote Originally Posted by pooldv View Post
    How long does this typically take? I mean ... I got to earn a living and go to work on Tuesday.
    TFTest Kits TF-100
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    What! That's blasphemy! Pools are all that matter! Some slams take a few days. Some take a few weeks. You look more on the couple days side of things since it's not a swamp.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    30,432
    You will also be able to continue around your work schedule. The testing and chlorine additions will slow down so you can start testing twice daily very soon.
    DFW, TX
    24,514
    Yep, go to work for more bleach money!
    cfclay's Avatar
    Apr 2010
    Little Rock, AR
    204
    Still cloudy water
    This may sound like a dumb question, but the morning I find that less than 1 ppm chlorine loss will be the morning that my pool is sparking?
    TFTest Kits TF-100
    30,432
    No, it would just be coincidence if that happened. You pool sparkles because you have filtered out all the debris, living and dead, in your pool.
    Passing the OCLT means you have killed virtually all the organics.
    cfclay's Avatar
    Apr 2010
    Little Rock, AR
    204
    Okay thank you. I'm there with the no chlorine loss in 9 hours overnight. Hopefully it will clear up soon, I have had pump running 24 hours for three weeks.
    TFTest Kits TF-100
  20. Back To Top    #20
    30,432
    The Intex pumps and filters are notorious for being slow to clear a pool.
    You might try just a little DE powder added to your sand filter. Just enough for a 1 psi rise. That often speeds things up.
