Results 1 to 8 of 8
Thread: Need help with portable vacuum
    Oct 2013
    Los Angeles, CA
    87
    Hello I am currently making a portable vacuum for my above ground pool. I have the pump and filter installed just need an idea of how to attach the vacuum hose to the pump and filter. Thank you fir the help
    Intex 12 by 24, Intex 2600 sand filter (soon to upgrade), deck under construction
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    Re: Need help with portable vacuum
    The inlet is easy. A bathroom sink tailpiece will thread into a threaded coupling and is just right to friction-fit a vacuum hose on. Alternately, Lowes sells these hose adaptors out with the pool stuff.
    Tailpiece threaded into a coupling
    Lowes hose barb
    Oct 2013
    Los Angeles, CA
    87
    Thank you for the help =] So a simple friction fit Will work ?
    Richard320's Avatar
    Jan 2010
    19,051
    Quote Originally Posted by florentino View Post
    Yep. Go to Lowes and grab the plumbing and sneak out to the garden section where the pool stuff is and test fit it in a hose.
    Oct 2013
    Los Angeles, CA
    87
    Alrighty then you for all the help
    FUBAR's Avatar
    May 2013
    Charleston, WV
    61
    I can't tell you how many times I've looked like a lost pup or someone meditating out in space at Lowes and had a associate ask if I need help only to (and I've got it hemmed down now) reply, "jimmy-rigging.." And it's like a code they all understand. That place should advertise has a health and balance facility as well as many times I visit the same two aisles 50x.
    10k gallon 22' AG Vinyl, 2k got Cartridge Filter, Fresh water, BBB Method baby!
    Oct 2013
    Los Angeles, CA
    87
    Same here I tend to send lots of time looking at all the possibilities in all aisles
    FUBAR's Avatar
    May 2013
    Charleston, WV
    61
    If terrorists had Lowes overseas we'd be screwed.
    Ok MODs, I'll put a shoe on this track to stop the derailing
