Page 1 of 3 123 LastLast
Results 1 to 20 of 51
Thread: Cloudy water and leaves in the bottom
    Jun 2012
    Farmington wv
    92
    I have been using bbb for the last few years. This year I never got around to covering my pool 24 round 4 foot deep. I did drain everything. I fill it all back up and started the pump and filter a week and a few days ago. I have killed all the algae but the water is still very cloudy. I know there are leaves in the middle I can see the dark ring. Should I try to clean the leaves out before I do anything else? Should I just net them out? because I can't see the bottom.
    This is the third summer on the sand filter 300 or 350lb can't remember. Does the sand need replaced or cleaned? It just seems like it's not filtering the water.
    I checked the water this morning with the Taylor test kit
    FC 13. Held over night.
    Cc 0
    Ph. 7.4 also tested at work with a ph probe and it showed 7.6
    Ta 80 tested at work shows 88
    Tds 1540
    Cya 30
    13500 gal 24 foot round x 4 foot deep above ground pool. Sand filter with 1.5 hp pump. City water
    30,419
    Re: Cloudy water and leaves in the bottom
    The sand does not need replaced.
    What is your psi? When did you last backwash.
    I suspect you just need a little more patience. You certainly need to net out everything you can to speed up the process.
    How are you chlorinating?
    Jun 2012
    Farmington wv
    92
    It starts at 5 psi clean and last time I back washed when the water almost quit moving from low return. I'm using 12.5% bleach. And have a liquidator I run to maintain.
    Aug 2011
    Central MA
    38
    You don't need to get all the leaves out to get a clear pool, trust me on that one. The guys here will fill you in on the details but in short, shock the **** out of it, leave the pump on overnight and in the morning you should have a clear pool. Once you do then you can work on getting those leaves out and then vacuum 1,234 times to get the rest of the dirt out. I'm on the vacuuming part right now and MAN is my water cold.
    One important part is MAKE SURE you backwash the filter every few hours otherwise you are filtering through a dirty filter and it just won't work. I'm no expert but I know what works for me.
    27 foot AG, CYA producing in-line Pent-Air Chlorinator.
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    I agree with Duraleigh. Get as much out as you can and the process will go much quicker. I usually just backwashing on the water flow from the return. When I notice it slows and I know the skimmer is clean the I backwash.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Jun 2012
    Farmington wv
    92
    The filter has not been off for over a week. I guess I should just use a big net to get them out?
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Yes, use a net to scoop the out.
    Lisa
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Backwash your filter when the pressure rises 20-25% over clean pressure.
    Jun 2012
    Farmington wv
    92
    I may have been wrong about there being no algae in the pool. I went and got a new net today and scooped the leaves out of the pool and it turned green. Dead algae won't turn a pool great right? I just checked and added some bleach and will check and add in the morning. Im hoping to get this thing clear soon.
    DFW, TX
    24,485
    That's right. Cloudiness indicates algae, green is the next step, then swamp. Time to SLAM Your Pool
    Please update your signature as shown here, What we need to know to answer your questions
    Jun 2012
    Farmington wv
    92
    I tested the water this morning and the FC was 14 if I keep it at 14 that should be fine with a cya of 30-35 right?
    DFW, TX
    24,485
    Yes, that is good. Test and add every 2-3 hours if you can, especially the first few days.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Yes, you should get all the leaves out. Everything you leave in like that puts a load on the free Chlorine. Remove everything possible.
    Essential Links:
    Jun 2012
    Farmington wv
    92
    I wish I could test every few hr. But when I came home from work today after 8 hr and some rain it only droped a few ppm of FC
    DFW, TX
    24,485
    Ok, good. Do as much as you can.
    Jun 2012
    Farmington wv
    92
    Just tested and FC is still at 12.5
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,380
    The algae was probably growing in the leaves and scooping out the leaves loosened all the debris into suspension. It will take time to filter out the fine debris. Keep the FC up and filter out the debris, backwashing as needed.
    Love TFP? Become a
    TFP Supporter!
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,476
    Good! You are on the right track. Do you think there are more leaves on the bottom? I bet they were hiding the algae and helping it grow.
    I have a leaf glupper and is WONDERFUL at getting large amounts of leaves out. Here is a link to what one looks like.
    http://www.ebay.com/itm/like/191345818256
    Keep the SLAM up and your water will clear. Watch your filter pressure and backwash as needed. You do not need new sand but you can do a deep clean if you have time. Do a search and it should come up.
    Kim
    Jun 2012
    Farmington wv
    92
    The water is getting better but still really cloudy. I am going to do the filter deep clean tomorrow after work. I have all the leaves out. I hope I can get everything cleaned up this week.
  20. Back To Top    #20
    Jun 2012
    Farmington wv
    92
    Just finished the deep clean. Sand had some sticky stuff on top of the sand. I spent an hour and a half and water was clear but not 100%.
