Thread: Help with Pool Claculator Please!!!
    whataboy's Avatar
    Jan 2015
    Lewisville,Texas
    53
    Cool Help with Pool Claculator Please!!!
    At bottom of calculator is has Suggested FC Levels
    SWG:2
    Normal:3 to 7
    Shock:15
    Mustard Algae Shock:24
    What do these numbers mean and when are they applied? THX
    Rick T.
    12,000 gallon IG Kidney shape,gunite,white plaster w/25% blue quartz (Chlorine)
    Jandy LED Multi-color pool light, ,Pentair VS Pump,Pentair FNS 48 DE Filter,Polaris 280 Cleaner
    TF-100 test kit, Taylor K-2006 test kit, Speed Stir, BBB Method, PoolMath, TFPC
    Jan 2012
    'burbs of Augusta, Georgia
    7,364
    Re: Help with Pool Claculator Please!!!
    Quote Originally Posted by whataboy View Post
    SWG:2
    Normal:3 to 7
    Shock:15
    SWG= Salt Water (Chlorine) Generator. SWG generally maintain pools well at lower free chlorine levels hence only 2
    Normal= a level of chlorine kept in the water (via bleach, tabs or whatever) to keep in the pool when NOTHING is wrong and everything sparkles. You would not want to go below 3, and unnecessary to go over 7
    Shock= Now known as SLAM level, the level of chlorine needed to kill off the algae cooties faster than the algae can itself reproduce
    Mustard Algae Shock= a less common type of algae that requires more chlorine guns. Kinda scary sounding to meeeeeee
    These numbers get generated in PoolMath when you enter *your own* specific pool chemistry levels into the program, along with your goals
    4knights's Avatar
    NE Kansas
    419
    The key is making sure your PH and CYA on correct, then you can set the SWCG for % run time you have pool filtering and enjoy
    Ron- Kansas. IG fiberglass, Riviera 30 Freeform 13600 gallons,
    EasyTouch 4 w/IC20 SWCG, Pentair Whisperflo 1hp, 2 speed 220 pump, Hayward ProGrid 4820 DE filter using Eco Klean instead of DE, 2 Savi Melody 12v 5 color LEDs, Raypack 266k btu millivolt heater, Arctic Armour Mesh custom safety cover (Total self Install) TF-100 test kit w/Magic stir.
    whataboy's Avatar
    Jan 2015
    Lewisville,Texas
    53
    Thanks for the help. Pool is sparkling clear. Guess I need to add a touch of bleach to get my number up from 1.5 to 3.
    Water temp is 75
    Rick T.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Chlorine needs to be maintained above the minimum level for your CYA at all times or algae will start growing, Chlorine CYA Chart
