Results 1 to 7 of 7
Thread: CSI?????
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    CSI?????
    Can someone explain why the CSI should even matter? It seems like if all your chemistry is within target range , the CSI would be irrelevant.
    Inground 13,200 gal Vinyl, Pentair 3/4 hp pump, Pentair Sand Dollar filter, Polaris 280
    Pool School, Pool Math, CYA to FC ratio chart, Testing Kits
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: CSI?????
    In your pool, no matter really, not unless your CH was outrageous. It's plaster where low, and a little high become a concern.
    Essential Links:
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    Re: CSI?????
    Gotcha
    But if the CH were in range in a plaster pool, the CSI would still be irrelevant right?
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: CSI?????
    No, TA and pH are critical factors. Temperature plays another role as well.
    Essential Links:
    30,432
    Re: CSI?????
    I have often preached that keeping your parameters within the limits we teach will result in a no-scaling condition. That is absolutely true for all but the most unusual of conditions.........say CH over 1000 for example.
    So unless you have something about your pool chemistry that is WAY, WAY abnormal, calculating CSI can be a teaching experience but it is not necessary to maintain crystal clear pools without scaling.
    38,524
    Re: CSI?????
    Agreed. Keep within the recommended ranges ... then CSI will be fine by default. If you are trying to live with something outside the recommendations, then you may need to pay attention to it.
    Low CSI does not really matter for vinyl or most fiberglass pools, but is very important for plaster.
    High CSI could be a problem for everyone.
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    Re: CSI?????
    Okay, thanks everyone. It seemed like just keeping everything in line was the only real concern.
