Results 1 to 7 of 7
Thread: How to change a Superflo pump from 230 to 110 Volts
    Oct 2013
    Los Angeles, CA
    87
    just want to make sure i do this right can someone please clarify how to make this pump into 110. Where would my black and while wires attach to?
    Intex 12 by 24, Intex 2600 sand filter (soon to upgrade), deck under construction
    38,548
    Re: How to change a Superflo pump from 230 to 110 Volts
    What does the wiring diagram on the side of the motor show?
    Is it a single speed or 2-speed motor?
    Oct 2013
    Los Angeles, CA
    87
    Jun 2012
    western NY
    1,563
    Once you bring your new 120 volt line into the motor it is simply a matter of changing the brown wire from the "A" terminal onto the "B" terminal and the White wire from the "B" terminal onto the L2 terminal. The hot (black) wire will go onto the L1 terminal and the neutral (white) onto the L2 terminal
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    38,548
    Well, it looks like you need to move the pump Brown from A to B and move the pump white from B to L2.
    Then I think you put your white (neutral) on L2 also with your black (+115V) to L1.
    That is the way i would interpret it.
    May 2015
    omaha
    6
    Can I ask why you want it to be a `110??
    25,000 G. Inground. Sandfilter
    Oct 2013
    Los Angeles, CA
    87
    Thank you for all the help. Am going to use this pump for a portable vacuum
