Results 1 to 7 of 7
Thread: My pool will never be clear again!!!
    Kannapolis, NC
    89
    I now own majority stock in clorox and my pool still hasn't cleared up I need answers
    _________________
    My Pool:
    Foxx Pool Grecian style 19' X 39'
    27k, with a 300# sand filter
    30,403
    Re: My pool will never be clear again!!!
    Quote Originally Posted by Bowlin
    Posting current test results (after any additives in the last 24 hours) for pH, Cl, ALk, CH, and CYA levels in your pool will help you get answers.
    Kannapolis, NC
    89
    brother carolinian,
    why dont you just come south about 2.5 hrs south and help a poor sole out!!!!
    However I have just added some cya to pool so I am not too sure on test results for the cya
    or any othe other for that matter just know that my chlorine level is at 17 this morning before coming to work.
    And my regeants are depleted for test cya but I will get the other results when I get home and post them.
    _________________
    My Pool:
    SeanB's Avatar
    Mar 2007
    Missouri City (suburb of Houston, TX)
    2,622
    This should help you out in making a good request for assistance. Your sure to get a very helpful answer if you follow the guidlines.
    http://www.troublefreepool.com/viewtopic.php?t=25
    TFP Founder
    My Pool: 13K gal IG gunite with 7' spa, Pentair Cartridge Filter, Intellichlor IC40 SWG, Polaris 280 Cleaner, TF-100 Test Kit w/ salt test.
    Central VA
    31
    Does it look anything like mine?
    http://troublefreepool.com/viewtopic.php?t=712
    It took a good two weeks and alot of bleach, but it's clear now. I only have a 5500 gallon above ground, and mine still took alot of bleach. Depending on your CYA, you may need in excess of 25 ppm to bring to shock. Once it is at shock level, keep testing it and keep it there. Also, make sure your filter is clean. I couldn't see 6 inches into my water when I started, and I had bugs and all kinds of critters in there. The two most important ingredients are bleach and patience!
    18' round Intex using BBB
    Fayetteville, Arkansas
    220
    When it comes down to a lot of frustration and tons of bleach ... do what I did. Drain and refill. Glad I did.
    20x40 30,000 gal IG Liner, Pentair II Sand
    SeanB's Avatar
    Mar 2007
    2,622
    No reasons to carry this conversation on in two threads.
    Let's just use this one:
    http://www.troublefreepool.com/viewtopi ... ight=#7492
    PS - I split part of this thread into its own topic (draining a vinyl liner pool).
    http://www.troublefreepool.com/viewtopi ... highlight=
    TFP Founder
