Page 1 of 7 1234 ... LastLast
Results 1 to 20 of 140
Thread: SLAMing and waterbugs
    May 2015
    Bridge City, Texas
    73
    Im in the process of slaming. still have water bugs swimming around and was wondering if that is normal only 2 days into it? was going to start a thread but do not have permission...I think. anyway, any info would be appreciated.
    thanks, joe
    28' round 22800 gal. half buried doughboy 6' deep end
    300# sand filter
    1.5 dynamo pump
    Pentair in line chlorine feeder
    TF-100 test kit
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: SLAMing and waterbugs
    Welcome to the forum!
    Before I can answer, how about posting some numbers please. First FC and CC, CYA to start.
    PM sent to post again with numbers.
    Essential Links:
    May 2015
    Bridge City, Texas
    73
    thank you jbizzle.
    heres my info:
    liner was replaced 5/4/15
    finished filling 5/5
    testsh-7.5
    cl-0
    ta-140
    ch-125
    cya-0
    temp-50*
    pool was slightly green added 7.5 lbs of stabilizer in pantyhose in front of skimmer milking frequently
    5/6
    1:30pm tests-cya:50ppm
    ph:7.2
    chl:0
    2:00pm added recommended dose of cal-hypo 65% to reach 20ppm. used cal-hypo because honestly all those bottles of chlorine didn't seem fun ...lol. and I could with a low ch, right? plan to use bleach once so much isn't neededor get too high with ch(cl/cya chart and pool calculator)
    3:45pm- FC:27ppm
    CC:0
    7:45pm- CHL:24ppm
    5/7/15
    6:20am - FC:19.5ppm added 24oz cal-hypo
    12:45pm- FC:23ppm
    and so I think im doing well but would like conformation from the pros. theres still little water bugs swimming around and I would have thought the slam level would have killed them already. could my cya be too high and chlorine not working well enough or does it just take a while? pool water seems to be clearing so im not quite sure. I would appreciate any advice and or instruction on mistakes you guys may see in my method so far,
    300# sand filter
    1.5 dynamo pump
    TF-100 test kit
    May 2015
    Bridge City, Texas
    73
    hello Patrick, thanks for the help. I pm jbizzle as I was having trouble posting is why I thanked him to begin my last post.
    any advice would be appreciated.
    300# sand filter
    1.5 dynamo pump
    TF-100 test kit
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Give it time, and keep the FC 20-25 and eventually they will likely die. I say that range so you minimize dropping below SLAM value between test and addition times. Stay with it and it will come around.
    Essential Links:
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    We have a few water bugs here and there from time to time. Not like a whole herd, but several at time I guess.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Say Joe, how did your water look when you started? Pretty dark or not too bad?
    Essential Links:
    May 2015
    Bridge City, Texas
    73
    great! thanks guys. yes Patrick, im trying to keep it a little high as I don't get to check and adjust as much as I should probably but I don't seem to be losing it very fast so hopefully I can keep it up. feel a little more confident now... thanks. I will keep posting my progress and if anyone sees any mistakes please feel free to line me out.
    thanks again.
    It was pretty dark Patrick. which surprised me considering it was fresh water. (city water supply)
    It's still pretty cloudy but the green tint is gone and I can barely make out the bottom of shallow end. will look into posting pics when I get a chance.
    300# sand filter
    1.5 dynamo pump
    TF-100 test kit
    May 2015
    Bridge City, Texas
    73
    4:30pm
    FC:17ppm added 35oz cal-hypo and swept
    300# sand filter
    1.5 dynamo pump
    TF-100 test kit
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Remind me where Bridge City is please.
    And that's fine, just keep the FC at or just above SLAM. You have room for CH with the cal hypo.
    Essential Links:
    May 2015
    Bridge City, Texas
    73
    East of Houston between Beaumont and orange Texas. I was just looking at "effects of adding chemicals" on poolmath and noticed the cal-hypo adds salt. Should I be concerned about this and testing for?
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Oh Ok. You say dark, but surprised with City water. How long did it take after filling to get that way? It shouldn't have been dark green upon fill...
    All forms of Chlorine add a little Salt. No need to test for salt unless you have a SWG. (Salt Water Generator)
    Essential Links:
    May 2015
    Bridge City, Texas
    73
    During install we filled about half way on 5/3 then finished filling on 5/5. So it had time to "grow". Lol
    I was afraid to add anything till I was able to turn on the pump.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Hey, no problem, we can fix that. I was slightly worried it was something else. Good deal. SLAM works, you'll see. Its just very important not to let your FC slip below value any longer than you can help it.
    Essential Links:
    May 2015
    Bridge City, Texas
    73
    I meant to mention this earlier but I've back washed twice since I started the process and both times the water in sight glass started dark brown almost reddish. Eventually cleared then of course I rinsed for a bit but was surprised by the color because it was nowhere in the pool. Maybe from the filter sitting without circulation for those few days allowed algae to grow in it?
    May 2015
    Bridge City, Texas
    73
    Patrick_B said:
    Today 06:29 PM
    Going to give it my best shot Patrick. Wife is trying to help while I'm at work but she'll be the first to admit it's not something she's too hip on. I've been reading this site now for a while even before I joined and am more than confident that with what I've learned and the help that is so freely given here it'll be the best it's ever been.(I never really applied myself to it thinking the pool stores had it all figured out for me. it was never really right, always on the verge of going green and chasing this or that test reading. Only took me 5 years and loads of $$$ to learn better, I can be a little slow sometimes) Truly a good thing you guys are doing here. It's appreciated.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Hey, no worries, and we are glad to have you with us. Thanks for the kind words about the forum. It's going to be an eye opener, and a new way for you now. You really will be amazed how easy it becomes. There won't be any more guessing, or wondering if the pool is going to be ok. Never too late, and seeing people get some knowledge and control of their pool is what keeps us coming back. There really isn't any mystery to pool care, and I love helping people find that out for themselves. If we can help her through this when you can't be there, she's welcome to come on, and we'll walk her through if she needs it.
    On the filter, not sure. That had to come from somewhere, but Algae won't grow inside it. See if it happens again, but no worries about it for now.
    Essential Links:
    May 2015
    Bridge City, Texas
    73
    8:15pm FC:26ppm
    300# sand filter
    1.5 dynamo pump
    TF-100 test kit
    May 2015
    Bridge City, Texas
    73
    She says it's looking better all the time. I'll let her know about the invite and report on that sight glass next time I backwash. Thanks again Patrick.
  20. Back To Top    #20
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Sure! Sounding good, and if you keep the FC there it will go well for you.
    Essential Links:
