Sandy Bottom
:wave: Welcome to TFP!!!
Nope. Sounds like 2 different problems.
1. You should not have air in your lines ... points to a suction side leak
2. Sand should not enter the pool ... points to a problem in the filter or backwash valve.
While looking into the filter for the problem, I found only 3 of the 8 laterals were attached to the hub. Also less than half a bag of sand left in the filter. Thank you for the guidance on my first problem. Now on to the new Since taking the plumbing off the filter, I now have to replumb. Are there any special pipes, glue, silicone that I will need?
