Thread: automotive quick connect for gas?
    Jan 2015
    San Jose, CA
    237
    my side burner came with a quick connect fitting, are they just the standard air compressor fittings?
    SF Bay
    ********20,000 gallon IG Fiberglass, DE Filter, Hayward Max-Flo VS, Taylor TF-100 Test, Circupool RJ-45********
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: automotive quick connect for gas?
    I would expect the mating piece to have more than the normal air fitting seal arrangement. Might also be a different diameter so you couldn't use air fittings.
