Results 1 to 18 of 18
Thread: Not maintaining fc level
    May 2015
    Kaplan louisiana
    69
    My fc level isn't maintaining. I shock the pool and the next day my fc level will be back at 0. I have a basic Taylor test kit which only test for fc and ph.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Not maintaining fc level
    Welcome to TFP!
    What you describe is perfectly normal. The chlorine could be all gone within an hour of adding it. You need to test and add chlorine as required very frequently until it holds. Check out SLAMing Your Pool to get the details.
    Jan 2012
    'burbs of Augusta, Georgia
    7,368
    Consider using liquid chlorine or even regular household bleach (not the scented, spashless or outside kind though) to bring your chlorine up again and again as needed. WHen you use a product called "Shock" it often is a "Stabilized" form of chlorine that also adds CYA to your water. Too much CYA causes problems and can't be removed unless you drain water off and refill with new water.
    May 2015
    Kaplan louisiana
    69
    Thanks, I'm going to try adding bleach and see what this does
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,071
    If you have no stabilizer (CYA aka Cyanuric acid) in the water, you'll lose pretty much all your chlorine within hours.
    If you have too much stabilizer, you might not be keeping enough chlorine in the water and algae is getting started.
    Did you just fill the pool? What does the water look like?
    http://www.troublefreepool.com/conte...efore-you-post
    May 2015
    Kaplan louisiana
    69
    The water is crystal clear. I have an in line chlorinator and my pumps been running constantly since Wednesday. I'm not sure about my cya levels.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Welcome to TFP!
    Need to know your CYA level. You need to maintain you chlorine based on your CYA level according to this, Chlorine CYA Chart. Otherwise algae will grow which will consume all your chlorine very quickly.
    Please update your signature as described here, What we need to know to answer your questions
    SLAMing Your Pool
    TFPC for Beginners
    You need to read this Test Kit Comparison and order a TF100 from tfteskits.net.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,197
    You have been given good advice. You need a quality test kit and the as John posted - SLAM your pool.
    Liquid chlorine will correct your problems. If pool stores in your are don't sell liquid chlorine at a reasonable price then plain bleach at WalMart will do.
    Support the site
    Casey's Avatar
    SW PA
    10,461
    You need a TF100as already posted and post up your test results all the while reading Pool School.
    Welcome to TFP. We can help You, if you help yourself to Pool School.
    May 2015
    Kaplan louisiana
    69
    Thanks for the help, I've added to my signature & just ordered the tf100 test kit. I'll slam the pool once I know my cya levels.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Good for you, and welcome to the forum. Your pool life will be way different than it ever has been. You'll actually enjoy it and not be wondering what's going on.
    Essential Links:
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Welcome and you will be amazed at how easy the TF 100 is to use and be able to easily maintain your pool.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    May 2015
    Kaplan louisiana
    69
    Ok my test kit came in & results are Fc 4
    Cc 1
    Cya 50
    Ta 90
    Ph 7.4
    Recommendations? I work away from home & before I left for the week the fc was 5 came home 7 days later at 0.
    13500 gallon above ground with pentair sand dollar sand filter, 1.5hp pentair pump with TF-100 test kit. Kaplan, Louisiana
    Smykowski's Avatar
    Sep 2011
    3,065
    With CC at 1 and FC at zero, you need to SLAM, the pool. CYA of 50 is about as high as you want to go for now, so take those pucks out.
    May 2015
    Kaplan louisiana
    69
    Ok, thanks. I'll start slamming this weekend without pucks
    Jan 2012
    7,368
    Do you work away from home often? Perhaps down the road you might want to think about a salt water chlorine generator (SWG) to help keep some chlorine (but no CYA additions!) in your pool those few days you're gone.
    Yippee
    DFW, TX
    24,514
    Before you leave take your pool up to shock level for your CYA based in the Chlorine CYA Chart
    May 2015
    Kaplan louisiana
    69
    Yes I work offshore on a 7/7 rotation (7 home then 7 gone)
