Results 1 to 7 of 7
Thread: I need a new liner
    Apr 2015
    Charleston/Illinois
    3
    I need a new liner
    I have a 18'x48" intex ultra frame pool that I purchased last year. I got it out of storage and a mouse has made two holes in it. How can I purchase another liner?
    38,546
    Re: I need a new liner
    Welcome to TFP!!!
    I am not sure they sell replacement liners for those. Can you just patch it?
    Apr 2015
    Charleston/Illinois
    3
    They are both located on the bottom and are around 2"x3" each. I am unsure if a patch would hold on the bottom.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,516
    Apr 2015
    Charleston/Illinois
    3
    Red face Re: I need a new liner
    Thanks, but they are out. I put it on my wish list.
    Quote Originally Posted by pooldv View Post
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Quote Originally Posted by skrich View Post
    Seems like they are always out. I cannot even find my liner on their site. Good luck.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Mar 2014
    Gulf Breeze, Florida
    67
    I used to have an Intex 24' pool and after about 4 years it developed multiple pinhole leaks. A replacement liner would have been about $650 (if they had it in stock).
    I bought a generic overlap liner off Ebay for about $200 and laid it inside the old liner. Had to cut out and patch the drain plugs and cut holes in the new liner for the filter connections. Secured it with clips and bungee...
    Worked great for the 2 more years before we moved.
    A plain blue liner for an 18' can be had for around $100. An added benefit of the overlap liner are they cover the top rails and protect from the elements.
    Chris Hawkins
    18,000 gallon vinyl Inground. Hayward Goldline Aquarite 40k SWG, Pentair Intelliflo VS pump.
    Polaris 3900 cleaner, Pentair Tagelus sand filter. AquaPro 1300 heat pump. TF-100
