Page 1 of 5 1234 ... LastLast
Results 1 to 20 of 94
Thread: Full week of slamming and not much progress Pics included.
    Apr 2015
    Flowood, MS
    45
    I saw great results last weekend starting my slam as you will see in the pictures below. However, throughout the week I started to get more of a grey green that is shown in the last picture (taken this morning). CYA is at 60 currently. Keeping the FC levels between 26 and 28 the best I can. Just ran out of the reagent that came with my Taylor kit so need to reorder some. This is my 3rd season with the pool and it didn't seem to take this long last year. Just wondering if I am overlooking something or if I need to be patient. I see that word used quite frequently around here ha. Thanks for any advice.dark_green.jpglight_green.jpgstale_green.jpg
    24,000 Gal
    Hayward Pump
    Polaris Booster Pump
    Sand Filter
    Polaris 380
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: Full week of slamming and not much progress Pics included.
    SLAM take patience. It is looking better though.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Hi, welcome to TFP! Nice first post!
    Looks like good progress to me! Keep slamming. I won't use the word.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,071
    I see some progress there. Like most things in life, the first 90% of the work takes only 10% of the time. The last 10% takes 90% of the time.
    Rerread the SLAM article and make sure you haven't missed something. And if the bleach appetite has noticeably dropped, you might be ready to consider some finer filtration by adding some DE or cellulose fiber to the sand filter as mentioned in that article. A caution: only do that when you're going to be around to monitor the pressure gauge. The filter can load up really fast when you first start that. It would be the equivalent of putting a window screen over a barbecue grate. You'll catch a whole lot more stuff.
    Apr 2015
    Flowood, MS
    45
    Thanks for all of your responses. Richard, I have not added DE to the sand filter before so I might need to do some research on that process. I will give this a few more days before venturing down that road. Thanks again, I'll post updates if things don't clear up.
    -Also, this is a great site! I've been a lurker for 2 summers so far. It has been super helpful!
    24,000 Gal
    Hayward Pump
    Sand Filter
    Polaris 380
    DFW, TX
    24,514
    Here is a place to start your DE in a sand filter research.
    http://www.troublefreepool.com/conte...-a-sand-filter
    Apr 2015
    Knoxville, TN
    64
    Hang in there. My SLAM took over two weeks this year.
    Sand filter
    Salt Generator
    25000 gallon IG Vinyl
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,014
    The SLAM is not a miracle cure. Its a process that will cure the pool of algae completely.
    that one is pretty ugly and would not clear up in a week in any case.
    It didnt get that way overnight, or even in a week. Its gonna take some time to clear it up. Hang in there man, and you will get it! the M in SLAM means Maintain the Shock FC level. Its critical to the timeline to keep the FC up!
    Divin Dave,
    Jun 2013
    Seguin TX
    192
    It takes time for the filter to clean the water, mine is still a little cloudy, remember how long it took to get this way, it will take some time to clear.
    2017-Intex Ultra Frame 16x48 5000 Gallons
    Intex 2800GPH Pump with 14" Intex Sand Filter
    My Intex Pool Setup Video :Intex pool rises from the ashes - installing and leveling - EP-72 - YouTube
    brmommy's Avatar
    Jul 2013
    Southeast Ohio
    74
    Quote Originally Posted by pooldv View Post
    Does any of the DE come back into the pool or does it stay in the sand filter?
    27' Round X 54" Aqua Leader Sentinelle AGP, Vinyl J hook liner. 18,500 gal.
    Waterway 19" oval sand filter, US Motors EZBN25 1.0 hp 1.5 SPL Pump, BBB (Empty Aqua Smarte System connected, may use during vacation), Barracuda Zodiac 1500,
    Taylor FAS-DPD K-2006 Test Kit.
    Apr 2015
    Flowood, MS
    45
    I have added the DE to the filter. I also checked ph and it has drifted up past 8.0, at least thats the highest the Taylor test kit will read. I have muriatic acid on hand, should I try to bring it back down? I know there is mention of the ph drift in the slam article so I don't want to waste the acid if I don't need to use it.
    24,000 Gal
    Hayward Pump
    Sand Filter
    Polaris 380
    Richard320's Avatar
    Jan 2010
    19,071
    Quote Originally Posted by oreolude View Post
    If FC is above 10, your pH will be reading falsely high. Pictures that prove it. DO NOT try to lower it.
    Apr 2015
    Flowood, MS
    45
    This is the update from today. 2 Full weeks now. Not much has changed this week. I had to take a sample to the local place this weekend since I'm still waiting on replacement reagents. Pool store said cya was at 0. I'm a little suspect on that test as it was at 60 earlier this week. I didn't think that could drop so far so fast. I have been backwashing once a day, is that too often? Thanks again for all of the help and suggestions.
    Attachment 35927
    24,000 Gal
    Hayward Pump
    Sand Filter
    Polaris 380
    DFW, TX
    24,514
    You should only backwash the filter when the pressure rises 25% from clean pressure.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Attachment 35927
    I can't see the picture, and I would not trust that store if you already got 60 yourself. If you aren't able to tell what your numbers are being out of reagent, how do you know you've been keeping proper FC levels?
    Essential Links:
    Apr 2015
    Flowood, MS
    45
    Quote Originally Posted by Patrick_B View Post
    I ran out towards the end of the week that's why I had to go into the store Saturday. I'm hoping everything will be in tomorrow. It is still about the same color as it was earlier in the week. Really hoping this week improves.
    24,000 Gal
    Hayward Pump
    Sand Filter
    Polaris 380
    Casey's Avatar
    SW PA
    10,457
    Have you raked all the debris off the bottom of the pool?
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    That's ok, you're probably just lacking FC level. Once you get refills, you'll know, and we'll be here to help.
    Essential Links:
    Jan 2012
    'burbs of Augusta, Georgia
    7,368
    I've learned here that backwashing too often can slow things down because a *slightly dirty* sand filter apparently works better than one backwashed to death.
    A smidgeon of DE can assist the sand filter. I bought a 10 pound box for $14 last year at Ace Hardware
  20. Back To Top    #20
    Apr 2015
    Flowood, MS
    45
    Pool is starting to look better. Got all my test agents. I am continuing to rake everyday and monitor levels. Had a gasket failure on the multi valve and that has been serviced. Been a rough start to the season but it'll work out. I'll post back at the end of the week with hopefully a good update!
    24,000 Gal
    Hayward Pump
    Sand Filter
    Polaris 380
