Results 1 to 8 of 8
Thread: Main Drain Plumbing
    dtrujillo63's Avatar
    Feb 2015
    Los Angeles
    33
    Main Drain Plumbing
    Should I be worried that my PB ran the main drain suction pipe to the skimmer, then from the skimmer to the pump? Is there a significant advantage to running dedicated pipes for both the skimmer and main drains directly to the pump?
    38,305
    Re: Main Drain Plumbing
    That is how both of my pools have been. But, it is certainly better to have them run independently to the pump. You have more control and can isolate the suction to the floor for draining if desired.
    Apr 2014
    Ontario, Canada
    49
    I'm certainly no expert, but for the few extra $ to run two lines to the pump and get the versatility to control the draw of water from either/combination of the bottom of the pool or from the skimmer, I'd go with it. But again, i'm no expert and certainly have enough of my own pool problems that I probably really shouldn't be commenting!!!
    18k IG vinyl pool, Jandy CV460 Cartridge filter, Hayward MaxFlo Variable Speed 1.5hp pump (SP2300VSP), Hayward Aqua Rite Salt Generator with 25K Gal Cell, Teledyne Laars Series One heater, Blood, sweat and tears manual cleaner (trying to decide what to get to replace me), no automation.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    It is convenient to be able to have all main drain for sweeping debris to the filter and all skimmer for extra skimming when needed.
    Feb 2015
    Los Angeles
    33
    So is it just a matter of convenience? Wouldn't the float valve in the skimmer give me the same granular control as a normal valve at the pump? I saw this pool plumbing video and it scared me, basically saying that my pool bottom can rot because there wouldn't be enough suction at the drains and that my pool chemistry will be harder to manage. I'd hate to have the plumbers redo this but if what the video is saying is true, I will. However, if it's just a matter of convenience, I'll leave it as is.
    https://www.youtube.com/watch?v=q84DsgnbfHI&t=2m52s
    DFW, TX
    24,497
    No, it is not a show stopper. The pool cleaner/robot will alleviate a lot of that. So will brushing.
    Also, welcome to TFP. Please update our signature as described here, What we need to know to answer your questions
    mas985's Avatar
    Pleasanton, CA
    11,741
    You can use the float to control the flow from the skimmer but I would not recommend reducing the flow from the skimmer. If anything you are better off reducing the flow from the main drain so the skimmer works better. Main drains are optional in pools and many pools are now being built without them so they are really unnecessary for proper pool maintenance and tend to steal flow from the skimmers which I think are much more important. Despite what the video says, there is no chemical settling if you actually run the pump when you add chemicals even without a MD.
    However, as was noted several times, the proper way to plumb a skimmer is with an equalizer line to a wall port and have the main drain on a separate line (or no main drain at all). About the only advantage of this setup is that it allows easier draining below the skimmer line because you can isolate the main drain.
    Mark
    Feb 2015
    Los Angeles
    33
    Thanks for all the replies everyone! I decided to stick with shared skimmer/drain plumbing. I do have a dedicated cleaner suction line so whatever vacuum I decide to purchase will be roaming around most of the time.
