Results 1 to 9 of 9
Thread: Pad for equipment
    Aug 2014
    NJ
    435
    Pad for equipment
    The PB is here today putting in all the equipment. They are putting it on a hard type plastic pad. For some reason I envisioned it would be on a concrete pad. How is it usually done?
    1200 Sq Ft 41,000 Gal. Gunite, JANDY SVRS VS pump, JANDY JXI 400,000 BTU, Polaris 280 w/ 3/4 BP, Rockwall and Grotto (w/6 jets and blower), 2 JANDY Lam Jets, 2 LED Bubblers, 5 Ledlights, AQUALINK P16 RS, 90% Quartz, SWF 185 GMP BP, SWF 125 BP, Levelor K1100 Autofill, AP Digital SWG, 2 skim and 5 returns, and mostly 3 inch piping
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Pad for equipment
    I guess this is something new to me. Usually it's a concrete pad.
    Essential Links:
    Feb 2014
    Upstate, NY
    390
    X2, usually concrete.
    20X36 IG vinyl (18,000 gal), 3 sheer descents, Max-Flo 1.5hp VS 2300, Aquarite T15 SWG, C3030 filter, 250,000 BTU heater, Sharkvac XL (Hayward equip)
    Concrete is most common, but you do see plastic pads from time to time. Plastic often has problems with filters. The filter weighs a great deal and you need something fairly solid to hold it up. They do make plastic pads strong enough for smaller filters, but I haven't seen one that can stand up to the larger filters we often recommend.
    Aug 2014
    NJ
    435
    Im getting a 560 Cartridge filter which looks pretty large to me. Unfortunately, nothing I can do about i now.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    That is a big filter. Make sure it is level to start with and check periodically to make sure it stays level, if not call PB to fix it. Especially if the filter is on one side or the other.
    Jun 2013
    Erie pa
    68
    I have a rubberized pad under my heat pump , no problems with it.I think it was originally made for ac condensing units.I seem to remember an ad on the internet for a complete line of pads for pool equipment.
    16x32 vinyl ig with foxguard steel walls,gli liner ,hayward de filter,hayward heatpro heat pump,hayward colorlogic 4.0 led.pentair circular weir skimmers.hayward sharkvac xl robot,gli mesh cover.polk atrium speakers,sonos music system.erie pa.
    Jul 2012
    Cary, NC (Raleigh)
    69
    I have plastic pads also. No issue going into 3rd year with anything moving or settling. They put the pool heater also in a plastic pad right next to the existing one so it looks good and also no issues. It was well leveled and installed so I'm sure that helps.
    We also had all our HVAC heat pumps replaced and plastic pads for those also without any issues a few years in.
    18x30 Freeform In-ground Vinyl Lined. 11,500 gallons.
    4 returns, 2 skimmers, 2 main drains.
    Hayward TriStar 1hp 2-Speed Pump. Hayward S244T Filter.Hayward Goldline Panel + SWG.
    Polaris 280 cleaner. AquaComfort 75k BTU Heatpump
    TF-100
    Aug 2014
    NJ
    435
    Good to know.
    Thanks
