Results 1 to 7 of 7
Thread: New build questions
    Jun 2013
    Fort Worth, TX
    68
    New build questions
    I'm building a 32x18 free form inground pool with spa and waterfall and have so many questions. I'm trying to tackle a few at a time! I'm going with jandy equipment, Vs pump for sure and cartridge filter. My questions are:
    1. What size pvc lines are ideal?
    2. What pump size do I need?
    3. Can the main pump run the waterfall with an additional actuator or should I just get a separate single speed pump?
    Fort Worth, TX
    Inground gunite 32'x20' freeform salt pool Coping: Flagstone Finish: Undecided Decking: undecided Equipment: All Hayward. 3hp VS pump, largest cartrifge filter, 400k heater Cleaner: undecided robot for sure.
    Start Date: Whenever it stops raining!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,496
    Re: New build questions
    1. What size pvc lines are ideal? 2"
    2. What pump size do I need? I don't know.
    3. Can the main pump run the waterfall with an additional actuator or should I just get a separate single speed pump? Yes, my 3hpVS pump runs solar panels, filter/skimmer and waterfall just fine at 1950rpm. Our waterfall is smallish, only one 2" pipe feeding it.
    38,290
    1. 2" is the minimum. Going larger on the suction lines, especially for the spa, can help.
    2. This is pretty hard to estimate no know the details of the plumbing and pool/spa. Realize that there are 2 things that affect the pumps flow rate: 1 is the pump design, there are small pumps (Super Pump, Superflo) and larger pumps (Super II, Whisperflo). And the other is the motor power which is a combination of the HP and the service factor (SF).
    3. This is possible, but it usually means you can not run the waterfall and the spa at the same time.
    DFW, TX
    24,496
    That is true, we do not have an attached spa.
    Jun 2013
    Fort Worth, TX
    68
    Thanks guys...I'm just getting more overwhelmed... Lol
    Fort Worth, TX
    DFW, TX
    24,496
    Just keep reading and let it all soak in slowly, it all starts to make sense eventually.
    Jun 2013
    Fort Worth, TX
    68
    Luckily my brother is my pb and he's got a good handle on everything. I'm just an over-researcher type person and try to know everything
    Fort Worth, TX
