Thread: skimmer placement phoenix
    Jan 2015
    Phoenix, AZ
    638
    I saw on a couples websites that skimmer placement should be downstream from return jets and down wind from prevailing winds. we r building a 40 x 12 rectangle pool. i was trying to keep the skimmer away from the baja step which downwind from prevailing winds here in phoenix. my pool will be in-floor with one skimmer. it's being built by california pools with the pv3 from paramount. it seems the pb is fine putting it wherever i want it, but it cost me more the farther i put it from the pool equipment.
    do i need 1 or 2 skimmers?
    can i put 1 skimmer upwind? thanks!
    40' x 12' IG shotcrete (3 1/2' 5, 4'), Hayward variable spd pumpSP3400VSP, Paramount PV3 in-floor, venturi skimmer, 14,400 glns, Hayward Turbo salt cell T Cell-15, UV, Hayward DE filter, model DE4820, 2 Hayward Color Logic 320 LED color lights, Hayward P4 w puck. 2" line to in-floor valve (46'), deck mount canister parascoping fountain, leaf canister, Marbella, pebble. new build 6-24-15
    Mod Squad pooldv's Avatar
    DFW, TX
    24,461
    Re: skimmer placement phoenix
    I don't think one skimmer is enough for a pool that size. But, to have any chance of one skimmer keeping your pool surface clean it has to be downwind. You can put it on the side of the downwind area, you just need to point the pool returns correctly for clockwise or counterclockwise water circulation to help the flow. Post a pic of the layout and we can help with that.
    Jan 2015
    Phoenix, AZ
    638
    thx. will i have returns or is the in-floor considered the returns? i thought the pb mentioned this unless I am mistaking it for something else that is not needed in a pool with in-floor.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    pooldv is right. You should have 2 skimmers on a pool that long.
    The skimmers should be placed on opposite long walls, equi-distant apart (or as close as you can reasonably make them equi-distant).
    The infloor cleaner should not be considered returns. You should have dedicated lines for that. What happens if something happened to the valve and the cleaner heads woldnt pop up? No return flow. And would not be good. You should clarify that with your PB though.
    Quote Originally Posted by outdoorsgal View Post
    Divin Dave,
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    I agree I would want two as well.
    Downwind of predominant wind. Wind will out do pool flow every time if it's very strong at all.
    Essential Links:
    DFW, TX
    24,461
    Pool returns are spread mostly equally around the pool on the wall a foot or so below water level. Separate from an in-floor cleaner.
