Results 1 to 10 of 10
Thread: What to put under an above ground pool
    Apr 2015
    East Wenatchee WA
    39
    Hi
    I am getting ready to set up an above ground pool.. we know to remove sod and level dirt. I am wondering about ordering the foam or bottom liner protector products rather than hauling sand. I know for sure I want the foam cove for the bottom edge where pool wall meets the ground. Any other pointers? Ideas? We previously (and on a different property) had an AG with a lumpy sand bottom and I hated it!!!
    15'x30' oval AGP. 12000 gal. 1 HP pentair pump. 19 inch sand filter.
    Auto vacuum thing that works through skimmer. Solar cover.
    OLD 400ish gallon Cal Spa hot tub with two new pumps (ouch)
    Re: What to put under an above ground pool
    Foam board has gotten popular for use under above ground pools.
    Apr 2015
    East Wenatchee WA
    39
    The foam they sell in rolls on the internet? or a hardware store product?
    Thanks
    Hardware store: rigid foam insulation board sold as wall insulation.
    Apr 2015
    East Wenatchee WA
    39
    AHhh..right... I know what that is...thanks... I bet its tons cheaper than the foam stuff on internet that's only 1/4" thick! Is the thickness an issue at all under the liner? I'm thinking for install we trim to fit exactly up to wall, put foam cove on top and instant smooth floor? Right? What about seams? are the panels cut in tight enough to not separate under pressure of water?
    Thickness isn't really an issue. Many people use 1" thick pieces, mostly because that thickness is readily available.
    You need to tape the panels together so they won't shift.
    You need to cut out places to put the pavers under the posts, and most people cut the edges down to match the pool shape so the foam board doesn't stick out.
    Apr 2015
    East Wenatchee WA
    39
    Thank you so much! Such a good idea to use the thick foam board!
    Casey's Avatar
    SW PA
    10,461
    Welcome to TFP!
    Orlando, FL
    690
    When you tape the seams they say tape over each seam three times. If you only use one piece of tape, the weight of the water will push the pieces apart and you will feel each seam and dirt will collect. Taping each seam three times apparently prevents this
    Sharkline Reprieve 15x52 (3/14). Still using Intex 2650 Sand Filter with Hayward Power-Flo Matrix 3/4 HP pump (6/15). Solar Cover cut into strips for easy removal, (2) 2*10 Space Saver solar panels. Swim Jet HD Robot (by Aquabot) (3/15). Chlorine Liquidator (4 gal). 4 person hot tub. Hard pipe is the way to go for improved flow! Retired Lil Shark (3/15). Starite Max E Therm 333k BTU Propane Heater w/ 24 gal tank (7/15).
    Apr 2015
    East Wenatchee WA
    39
    Thanks for the tape reminder. !!
