Thread: PVC leak at Multi-port
    We have a leak from the sand filter to the PVC leaving toward salt generator. I've attached photo with arrow pointing to leak. Doesn't seemed to be cracked, but hard to tell. We've never had a problem before but we do have limited experience repairing home pipes. Can someone help us? Thank you!
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Re: PVC pipe leak
    Is this a threaded joint or is the white pipe glued into the black?
    Not an expert but it seems to me the threads on the outside of the valve would have been the correct connection.
    -- Guy --
    38,275
    Re: PVC leak at Multi-port
    I agree that must be a threaded connection, but pretty odd they did not use the exterior threads to not restrict the flow some much at the joint.
    There might be just enough pipe left there to cut off the fitting that goes into the filter, and add a new fitting and coupler ... better yet, use a union instead of a coupler to make it easier to get into the top of the filter if needed.
    Mar 2011
    441
    All top mounted multiports should have unions. Pentair makes a kit for it, its this one. http://www.amazon.com/Pentair-150119.../dp/B008GT5OUI . It threads on the outside of the valve.
    20X40 30,000 gallon gunite pool
    If I understand correctly, I need to order the Pentair kit and cut where the threads go inside the valve. The new connection will be outside threads, rather than inside, the way the pool installer "experts" installed it.
    38,275
    that is one option. or just get a regular union and a new fitting to put on the filter.
