Page 1 of 2 12 LastLast
Results 1 to 20 of 27
Thread: cya is 90, have to replace 50% of pool water?
    I am a newbie - last year was first year with inground pool and I think I did okay but I admit I have not been testing the water often recently other than PH. I just tested CYA for the first time in a long time and it was 90. I put a target of 45 in pool math and it says replace 50% of the pool water with new water. Is this the only solution??? I don't like having to spend money to replace that much water. If I have to do this should I do it ASAP or should I wait until mid May when I hope to start using the pool again. Please advise, thanks!
    --- I just read in another post to not use chlorine tablets. Well I stopped using bleach and was using packets of shock (was leftover from previous homeowner so i was trying to use them to save money) to keep my chlorine level high enough over the winter and I guess that may have backfired?
    Greenville NC
    14,657 gallons IG vinyl pool 14x28
    1HP A.O. Smith Pump Polaris 9550 sport robotic cleaner
    Pentair Tagelus high rate sand filter 04C TA-60/60D
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: cya is 90, have to replace 50% of pool water?
    Hi Matthew and Welcome!
    Yes, as it stands that is the only option. I would suggest that you start working on it now rather than later.
    Have you looked into the water cost? Typically is really isn't very much.
    Lastly, may I presume you now how you got to 90 PPM Cya?
    Essential Links:
    I assume I wasn't testing it enough so it just got higher and higher because I never added anymore CYA since the beginning of last pool season? using packets of shock to chlorinate over winter was a mistake? thanks for the info!
    I think I'm going to have to call a pool person because I am unsure on how to dump half the pool water out.
    Greenville NC
    I would lower CYA to 60, and let it drift down from there on it's own. That would be a 1/3 water replacement.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Dittos to what Patrick & Jason stated above - a partial drain & refill is the only practical way to lower the CYA level.
    Quote Originally Posted by Matthewmon
    If the packets of shock contained either dichlor or trichlor then, yes, this would have increased CYA. If the shock packets contained calcium hypochlorite, that adds calcium and will temporary turn the water cloudy for a day or so.
    Jan 2012
    'burbs of Augusta, Georgia
    7,348
    Quote Originally Posted by Matthewmon View Post
    Each pool is a bit different, but on *my* pool, if I wanted to drain water out I'd use my valve handle to close off the skimmer and leave the main drain (the drains down low) wide open. I closed the skimmer so as to not suck in air through it when the water lowers below it.
    ...then after cutting my power off, I'd turn the multiport valve handle on top of my sand filter to the "waste" setting, and then turn the power back on.
    ...then I'd let it go (just like as if I was backwashing, except on "waste" it bypasses the sand entirely) until it got down the desired amount.
    ...then replace the missing water with my fresh fill water.
    Sometimes people have to do this a few times to eventually exchange all the water in their pool for metal or cya free water. Just be careful not to drain too much at one time as that is risky to the pool to be too empty. Draining 1/3 should be no problem. If I wanted more out I'd drain-refill-drain again-refill, rather than risk going too far at one time (I'm cautious like that )
    Another option is to use a small sump pump (comes in handy for various pool purposes, so worthwhile to buy IMO) and just drain it that way. A third way to drain is to use a simple garden hose to siphon it down if your yard is sloped enough.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    You can go to waste as Yippe says. Backwash some before you are done, but not more than you normally would with a regular backwash. Doing that excessively isn't good on your filter.
    Second option is to rent a sump pump from Home Depot and use that.
    Essential Links:
    thanks for the info guys! I'll try what you said Skippy. When I just turn it to waste and turn the pump on the water comes up out of a drain in my yard and floods it so I can only do a little at a time and it would take weeks to remove 1/3 pool water lol. I'll try your method.
    Greenville NC
    I just closed off the skimer and the water is still coming out of the drain in my backyard? I guess I need to get a sump pump does it come with a hose to get the water all the way to the street?
    Greenville NC
    Jul 2012
    Cupertino,CA
    45
    I don't know what it will cost to rent one, as suggested, but I recently purchased a small pump from Harbor Freight.
    I don't have the receipt handy but I think that I spent $75+_. It attaches to a standard 1/2" garden hose, that you can feed into a sewer clean-out.
    I don't know where you live, but some areas really frown on sending pool water into the storm drains, as it feeds directly into local creeks, etc...
    just a thought
    12,000 Gal plaster pool & spa.
    Jandy 2.7HP V.S. e pump, with IQpump control.
    Jandy AquaPure 1400. Jandy PDA.
    Solar heat. Jandy 400btu ng heater.
    Pentair 420 cartridge filter. Polaris 360 sweep.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,496
    You can usually rent a sump pump that you can connect a garden hose to.
    there is a pump thing that pumps underground water out near my regular pump. they pool guy said it was a good thing to have. maybe it can be used to pump out water or is it only for the underground water - pool guy said to use it after a big rain. I can plug it in but don't know how to turn it on???? The pool guy used it before but I have never used it...
    Greenville NC
    DFW, TX
    24,496
    It probably has an automatic float switch to turn it on and off.
    the underground water thing is a berkeley 10sn shallow well jet pump so nevermind on that its not going to help.
    Greenville NC
    DFW, TX
    24,496
    You might be able to open the valve on your filter to drain the pool into the drain well and have the sump pump pump it away.
    elwood58's Avatar
    May 2012
    Sun City West Arizona (2nd Home)
    653
    I rented a pump from Lowes that came with 100 feet (2X50) of 2 inch hose. Cost was $40 for 24 hours, and less for six hours. I pumped 12000 gallons in 6 hours.
    19204 Gallon L Shape with a 10X10 2nd Step Baja Ledge. Intellichlor IC-40, IntellipH, Cartridge Filter, Pentair Heater/Chiller (Heat Pump). Tons of Deck with Deck Jets. Construction Complete 6/5/17.
    "If you don't measure it, you can't manage it!"
    Jul 2014
    Sacramento, CA
    241
    To join the chorus -- I bought a 1/6 hp pump from Harbor Freight for around $40 (was on sale and with a 20% off coupon), connected that to 2 hoses in line (150-200' in total?), and ran it to the cleanout in the front yard. It took 2+ days to drain 1/3 of my ~20k gallons, but there was no rush so it didn't matter. Doing it again i would buy the next higher pump (1/4 or even 1/3 hp), as the flow was a lot slower with all that hose than I had expected.
    In my area water isn't expensive, so refilling the whole pool would only be $30-$40, but YMMV. It's worth doing a one-time drain to get things where you want them; in general my understanding is that if you follow the methods here you won't usually need to drain often if at all after that.
    21000gal IG plaster, Sacramento CA area (late 1950s/early 60s)
    Filter: Cartridge, Pentair CCP420 (2014)
    Main pump: Pentair IntelliFlo VS (2015)
    Boost pump: 3/4hp (2011), Polaris 280 cleaner (unknown age)
    Mar 2015
    Southern California
    25
    I just had to drain for the same reason as you. Except my CYA level was probably well over 200.
    I used the 1/6 sump pump from harbor freight. Put it on the top step and pump into your sewer clean out. I would drain down to the point of almost losing suction, then I would start filling with another garden hose at the bottom of the deep end.
    My pool is approx 27 k gallon. So I had to repeat the process over a couple days.
    Aug 2014
    Biloxi, MS
    10
    My process was basically what Yippee and TK did. Waste/refill over several months periodically last season, only taking the water level down to that of the skimmer; now my CYA is around 45, down from a high of 100+. And I use bleach exclusively, no more pool store visits for me!
    Edit: I highly recommend the TFT test kits; this basic tool is a requirement of you want to keep your pool in top shape
    10,000 gallon / fiberglass / IG pool
    Pentair Nautilus FNS24 D.E. Filter
    Hayward 3/4HP pump
    Build/Install date: June 2003
    Polaris 360
  20. Back To Top    #20
    Aug 2014
    Shallotte, NC
    693
    This was touched upon, but to reinforce.... using any kind of solid chlorination is going to introduce CYA. Check out the use of bleach, instead.....
