I found a good deal on this test kit. Not sure if it will do all I need for a TFP. What is the difference between the 2005 and the 2006? I couldnt find the 2005 on this site anywhere but im not very pc savvy either. Thanks guys!
Just as a very quick answer I'm pretty sure the 2005 comes with the "wrong" chlorine test and not the FAS-DPD type test that you need to test and follow TFP methods!
I'm sure someone with more info will post soon to confirm this!
The other issue with a "good deal" is that you may get old/expired chemicals/reagents. If you are sure of the chemicals and it is still a good deal factoring in the addition of the FAS-DPD test is may be worthwhile.
Exactly what i was going to say. If it is a great deal, and has newer reagents, then adding the FAS-DPD might be worth it. Other than that, the TF-100 is the best deal.
