Page 1 of 2 12 LastLast
Results 1 to 20 of 40
Thread: Water Temp target for FC
    Feb 2015
    Savannah GA
    21
    Hello! I am new to the forum, so thank you for listening!
    Just got a brand new vinyl liner and decided to switch to a SWG since the water was going to start fresh. I have been slowly getting the numbers right, however, my TAC and FAC are still at 0. Can you tell me if I should go ahead and shock the pool to start the chlorine now, or should I wait until my SWG is producing enough? The guy at the pool store recommended Fresh and Clear to use as a shock due to the pool now using salt. My SWG has been reluctant to allow settings above 25% and the water temp has just reached 72 degrees.
    Current readings are (checked at store and home kit)
    FAC: 0
    TAC: 0
    Salt: 3500
    CH: 300
    TA: 100
    pH: 7.4
    26,500 gallons, 18X36 In ground pool with vinyl liner
    Hayward Pro Series sand filter, new sand.
    SWG, Autopilot Nano +
    3/4 HP pump running 24 hours now during SLAM.
    30,419
    Re: Water Temp target for FC
    Welcome to the forum.
    You need chlorine in your pool pronto..... use bleach while you are sorting things out.
    What is you CYA measurement and someone can tell you how much bleach?
    Pool store guy wants you to buy stuff....we want to help you understand why you don't need to.
    read "The ABC's of Pool Water Chemistry" up in Pool School for starters
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Welcome to the forum Dan
    What he said Do you have a test kit yet ??
    Solar Blanket, Well Water, Borax Added. 68°
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Yup, what they said!!! Stay away from the pool store - they will just try to lighten your wallet.
    If you don't already have one, you will need to pick up one of the recommended test kits. To effectively practice the TFPC methods, the FAS/DPD chlorine test is essential. All the kits on the list contain that test while very few other kits do. The kits sold at the pool store generally won't won't cut it, but be careful pool store employees are known to say “it's the same thing”. Generally it's not!
    And, you really don't need to run your pump 24/7. All you are doing is paying the power company money they don't need.
    Support the site
    Forget about the Fresh and Clear. Once you get the correct amount of chlorine in the water, you should do an Over Night Chlorine Loss test to see if you need to Slam the pool.
    See the links in my signature for the place to get the best test kit and a video of how to do it.
    http://www.troublefreepool.com/conte...loss-test-oclt
    Support the site
    Feb 2015
    Savannah GA
    21
    Thanks guys! Yes, I have a test kit. The best one that they had at Leslies Pools. Seems to be right on the money matching up against the store tests. My CYA is reading 97. Per this site's calculator I need to add about 2 1/2 gallons of bleach to get my FC to around 6? What does that equate to in PPM? The values say 5 to 13 instead of a ppm reading? One other question, what kind of bleach is 6%?
    Since your chlorine is 0 ppm, I would suggest going to 10 to 15 ppm and doing an OCLT to see if a full Slam is indicated. The numbers recommended are in ppm. You really need the FAS-DPD test to measure your levels correctly, especially since your CYA is so high.
    Regular bleach is now 8.25 % sodium hypochlorite. Make sure that you only get "regular" bleach for standard machines. Don't get any special use bleach such as "Outdoor", "Splashless", Scented, High efficiency etc. Make sure that it shows 8.25% sodium hypochlorite on the label. If not, don't get it.
    Support the site
    Feb 2015
    Savannah GA
    21
    Thank you James! I appreciate the info on the type of bleach to use. My "deluxe" kit was lacking the FAS-DPD test! I am giving up on Leslies! Not much of a choice here in Savannah unfortunately! I wish the "calculator on this site would give you more of an exact reading as far as ppm's are concerned about the chlorine! Does anyone know what 6-13 translates to as far as ppm? I am going to start with 2 1/2 gallons of bleach and go from there. I will post my results and try to calculate the ppm's.
    May 2014
    Franklin, NC
    9,184
    Quote Originally Posted by SavannahDan View Post
    You can add the FAS-DPD. You probably bought Leslie's version of the Taylor K-2005, and at about twice the price I'm sure.
    Good idea. If you follow the methods taught here you will no longer need to go in a pool store. Wal-Mart, Home Depot or Lowes will sell you everything you need.
    6 - 13 is 6ppm - 13ppm No translation needed
    Support the site
    Feb 2015
    Savannah GA
    21
    @Tim, Thanks! I have indeed ordered the test kit for the FAS-DPD to add to my kit. I got the 81-330 version. Live and learn! Thanks for the clearing up the ppm question! I guess I couldn't see the forest for the trees! LOL I will post again on this thread when the results are in! I had a pool guy for the last 5 years while I was overseas. Time to learn to do this myself now that I am home!
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    May 2014
    Franklin, NC
    9,184
    No problem. I just looked up that kit and see it only has the 3/4 oz bottles. You will be replacing some of them quickly.
    TFTestkits.net is the sponsor of this forum and sells all of the reagent refills you will need. It helps support the site.
    You can also become a site supporter to keep the lights on if you feel you get value from the site.
    Support the site
    Feb 2015
    Savannah GA
    21
    @Tim! Thank you very much for the info! I will be ordering from them from now on. Love to save $$!
    May 2014
    Franklin, NC
    9,184
    Anytime. Did you see my comment about your pump run time? Every time I read your signature I just see $$$$$$$$$$ heading out the window. Check out Determine Pump Run Time
    Support the site
    Feb 2015
    Savannah GA
    21
    Oh yeah, donated to the site too!
    Feb 2015
    Savannah GA
    21
    A quick update of my readings. After adding the recommended amount of bleach and obtaining a FAS-DPD kit. I now have Chlorine readings of 7.25 FC and 1 PPM CC per my test results. Getting some rain here and tons of pollen, so I have let the pump run 16 hours a day to keep it clean. My SWC output is only happy when set at 15% or below. If I set it any higher it gives me a no output/low amps warning. Water temp is still only 73 however so I expect it to improve as we warm up. Any comments are welcomed! LOL
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    I would only add that a 10 mil sample on the FC is adequate and plenty accurate.
    Thank you for supporting the forum too!
    Essential Links:
    Feb 2015
    Savannah GA
    21
    Patrick, I did indeed use the 10 mil! Figured it would save some test material!
    The 10 ml sample has a multiplier of 0.5. 7.25 would not be a valid number.
    Support the site
  20. Back To Top    #20
    jtaves85mcss's Avatar
    May 2012
    Cincinnati, OH
    189
    Wait, What? In post #6 OP remarks that CYA is at 97, after a recent liner instal?? What test method was used to determine that? Seems suspect and you need a good CYA for chlorine dosing min and target, right?
    Pool: IG 22k- 16x32 clipped corners- vinyl liner, w/ a great board. Built in 3/99, new to me 2/2011.
    Equip: Hayward 3600 DE filter, Hayward CL-200 Chlorinator (empty since 7/5/2013).
    K-2006 Test kit with Speedstir
    Located in Cincinnati, OH. TFP lurker since 9/2011, BBB interested since 5/2012 and converted 7/2013.
