Results 1 to 7 of 7
Thread: Hose From Solar Panel
    Nov 2014
    Dade City, Florida
    94
    Just wondering if I can use a vacuum hose to bring water from my solar panels back to the pool. The reason I ask is because its a 20 foot run and the longest hose I can find is 6 ft and its a hassle to splice them. Thanks !
    38,248
    Re: Hose From Solar Panel
    Why not use PVC pipe? Or PVC hose? Slapping on some primer and solvent and a coupler is not that hard.
    A hose might work, but it adds a lot of head loss and lowers flow rate due to all the grooves.
    Nov 2014
    Dade City, Florida
    94
    Where can I buy 20 feet of PVC hose?
    38,248
    I know my Ace hardware sells it by the foot off a huge roll. I think they call it spa hose or something like that. Or at a pool store (one that does installations). Be ready for sticker shock though.
    Where are you running it? If just along the ground, you could use hard PVC for that part and the flex for the ends as needed.
    Nov 2014
    Dade City, Florida
    94
    It is along the ground. I have never worked with pvc but I have a handyman that can do it this weekend. Might as well hard plumb everything. Thanks for the advice.
    Just curious....What is the best way to make a 180 degree turn?
    38,248
    Use two 90 degree fittings.
    Nov 2014
    Dade City, Florida
    94
    Makes sense Thanks.
