Thread: VSP Settings
    Mar 2015
    South Florida
    43
    VSP Settings
    Right now the pump is setup full speed 3450 rpms from 12 pm to 4 pm and 1750 rpms the rest of the day/night. I am assuming it will be like this for the first month after opening. What will be good setting/schedule for the pump on the pool?
    12K gallons, IG, Durazzo, Pentair cartridge filter, Jandy ePump JEP2.0 VSP , Pool started March 2, 2015, South FL
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: VSP Settings
    No, not necessarily,
    Everything with startup is done? If so, you can go to a more normal run time setup. Check out the article in Pool School on that.
    Pump Run Time Article
    Welcome to TFP by the way.
    Essential Links:
    Re: VSP Settings
    For the first few weeks after fresh plaster is applied it is good to run the pump 24/7. Full speed is not normally required, something in the 1750 to 2200 range is more normal. After the first two to four weeks you can switch to a more normal schedule as Patrick_B suggested.
    Mar 2015
    South Florida
    43
    Re: VSP Settings
    Thank you Patrick and Jason. I will leave it as it is for a couple of weeks until I become more familiar with chemistry and testing. Then I will start adjusting the run time.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: VSP Settings
    Good deal,
    Most pools can run well below the standard suggestions of 12+ hours per day. A lot of PBs suggest this, but most of us run much shorter times. How much debris you have getting in the pool plays a large role in this.
    Essential Links:
