So I'd like to thank everyone for all the help, made some huge progress! Pool is finally as complete as I can make it right now, got the new pump all plumbed in (pictures included) , pool room is all tidied up, pool is balanced, unfortunately I had to hire someone to find the leak and it turns out it's in the cover for the niche, water epoxy will do the trick to solve it for now, until I replace the liner which i know has to be replaced anyways. This pump definitely moves a lot less water than the little, although I can't say that's a bad thing overall but I'm curious how vacuuming will go now (will test in the next couple of days once the pool warms back up lol), the slow speed the water looks stagnant almost haha, I'm sure you don't need it to be moving much though to circulate. And it does put a lot less pressure on the sand filter, it's down to 18psi vs 24, nothing crazy but better none the less.
Got my AirExchanger fixed.
My CYA is 30~ now, my FC is 4~, I found a place to get R-0003 (and all other reagents) locally, it's like 38$ a bottle but if i'm just picking up odds and ends I feel like it'll be cheaper than ordering it.
Now I just need to replace the liner, get a new pump for my SPA, Epoxy some problems in the SPA, make sure there is no leak, I want to replace that flex pipe that the guy installed (makes it look sloppy), and I'd like a better heat exchanger but from what I can tell they aren't cheap haha, I also need to replace a o-ring on a valve at the slide, it leaks so it's always "on" and it's starting to leave a stain on the slide.. Also need to figure out how to get this timer working properly, I have found both clips while cleaning so it should work in theory.
