Thread: Installation Question for SWG
    Can a SWG system be installed on a vertical return to the pool? If so, is it just as efficient?
    cmlampa
    14 x 28 x 5ft
    Hayward Sand Filter
    11000 gal, IG
    concrete
    1 HP Hayward Pump with timer
    Jun 2011
    Long Beach, CA
    2,789
    Re: Installation Question for SWG
    Do you have a SWG already or are you searching for one that can be mounted vertically? There certainly are some that can be mounted vertically and they will produce the same in either fashion. You just need to make sure the flow switch is mounted properly in the design.
    Hayward's Aquarite is a good option for you and it can be mounted vertically.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Yup. +1 what Ping said.
    Divin Dave,
