Thread: Sodium ions accumulate?
    Dec 2014
    San Diego, CA
    1
    So, I have a related question: in a fresh water pool, where sodium hypochlorite is added periodically, do the sodium ions accumulate over time or go somewhere?
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: What happens to the Na+ ions
    This makes me wonder now......what are my Sodium Ions doing out there in that cold water.
    I think I'll go check on them today.
    Essential Links:
    Mar 2007
    San Rafael, CA USA
    12,082
    Quote Originally Posted by ratherbeswimmin View Post
    Welcome to TFP!
    The sodium ions accumulate and when the chlorine is used/consumed including being broken down by sunlight, that produces chloride ions and they accumulate as well. So what accumulates is sodium chloride salt. The water becomes saltier over time and is only reduced in concentration by water dilution/replacement. More technical details are in this post.
    So when manually dosing with chlorine, there is an accumulation of sodium chloride salt. When using a saltwater chlorine generator (SWCG), there is no such accumulation because the sodium ions don't participate in the reactions and the chloride ion that becomes chlorine in an SWCG reverts back to chloride ion again when the chlorine is used/consumed.
