Saltwater IS a chlorine pool. The only difference is the chlorine is generated from the salt instead of being introduced via bleach or trichlor tabs. After oxidizing the organics, the chlorine is turned back into salt and ready to be used again. With salt, you add it once and then only add to replace what gets splashed/drained out.
In my experience, it's a bit easier to manage a saltwater pool, so I'm doing it again with my current build. I highly recommend it.
So if you don't like weekly trips to [fill in favorite store here] to purchase bleach, by all means go for the salt system. If you spend enough time on here, you'll quickly realize that "chlorine tabs" really aren't a viable long-term option.
