Page 1 of 3 123 LastLast
Results 1 to 20 of 55
Thread: Have been having algae problems
    Nov 2014
    Ft. Lauderdale, FL
    79
    I too am new to pool ownership. I bought my house with a SWG and have been having algae problems. They come up as spots on the walls of the pool. Per the advice of Leslie's, I have shocked on multiple occasions and it keeps coming back. Now I'm going to try the TFP method to see if that helps.
    I do have a question tho, since I have a SWG how should I go about raising my FC level?
    Thanks
    15,000 Gal IG Pool | Autopilot SWG | Baracuda G3
    Filter Cartridge
    Taylor TF 100 Test kit
    A O Smith USQ1102 1hp single speed pump
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,008
    Re: TFPC for Beginners
    Quote Originally Posted by Dustballs View Post
    Thanks
    Welcome!
    You won't be able to raise the FC level high enough fast enough using the SWG. You'll need bleach. And a proper test kit. The instructions are all here in Shock Level And Maintain
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,525
    Re: Have been having algae problems
    Hello there! You have a great first step-Finding TFP!
    You next step is to find a good, local, cheap bleach source.
    Then order a GOOD test kit. See my siggy below to see what test kit you want BUT I think you need to XL one since you are going to need to SLAM.
    Good luck! Let us know when your test kit comes in so we can guide you through them.
    Kim
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,609
    Welcome to the forum. Please add a signature line to your profile listing your pool specs for us.
    Sep 2013
    Dallas-Ft. Worth Metroplex, TX
    810
    14K Freeform Gunite w/60% Blue Quartz plaster, Quad DE filter, Intelliflo VS Pump + Booster for Cleaner, Aquacal Heat Pump
    Nov 2014
    Ft. Lauderdale, FL
    79
    Thanks all for your help.
    I wasn't sure if I can add bleach since I have a SWG.
    I will begin SLAMMING right now (off to get some bleach). See my test results below
    FC - 0
    CC - 0
    CH - 325
    TA - 80
    CYA - 50
    PH - 8.2
    Salt - 2800
    Filter Cartridge
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Don't forget to grab some acid to lower your PH ! The low 7's for the SLAM. What test kit are you using ? 😎
    Jeff
    Nov 2014
    Ft. Lauderdale, FL
    79
    I just added acid to lower the PH.
    How long do I have to wait to test the PH again?
    I'm using the Taylor TF100 test kit
    Filter Cartridge
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    You should be able to retest in 20 mins. Make sure pump is running. 😎
    Jeff
    Nov 2014
    Ft. Lauderdale, FL
    79
    One more question before I start to SLAM.
    The Chlorine/CYA chart starts at a CYA level of 60. Mine is currently at 50.
    What should my shock level be? FC of 20?
    Thanks
    Filter Cartridge
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Yep your shock level is 20. Shock level on both non SWG pools and SWG pools is the same. 😎
    Jeff
    Nov 2014
    Ft. Lauderdale, FL
    79
    Just added 2.5 gallons of liquid chlorine. Hopefully it's not too late in the night to start the process
    Filter Cartridge
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Your fine starting at night. I recommend starting a SLAM at night. During the summer starting as soon as the sun is off the pool. This takes the sun out of the equation, no FC burn off from the sun. That way all the chlorine can be used to start killing algae and get a good head start on it. 😎
    Jeff
    Jul 2012
    Tallahassee, FL
    30,525
    Not too late. Check it in an hour and redo as needed. Depending on the FC drop you will want to do it every hour until you go to bed. Big drop=every hour, little drop=every other hour.
    Check it as soon as you get up in the morning.
    Test and dose at least 3 times a day. The more you keep it at SLAM levels the faster it will go.
    I hope it goes fast for you!
    Kim
    Sep 2013
    810
    Make sure you turn off the SWG while you are chlorinating manually, or you will end up with more than you bargained for!
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Welcome to the forum Dustballs
    Or, leave the SWG on since the pool will be using it up anyway. Since his first set of results has the FC at 0.0 it's unlikely it's generating much. Once the SLAM is done they will need to crank it up some and or run the pump longer daily. That and bring up the CYA AFTER the SLAM.
    The only time you really need to make sure the SWG is off is when you do your overnight chlorine loss test (OCLT).
    Solar Blanket, Well Water, Borax Added. 68°
    Nov 2014
    Ft. Lauderdale, FL
    79
    Thanks.
    I turned it off about an hour ago. Will turn it back on in the morning.
    Filter Cartridge
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    It's one of those things were you'll get different opinions and I used to say shut it off during a SLAM and then someone pointed out an error in my thinking. That and the fact that you have the SWG already, why not use it and cut back on some of the bleach you'll need to carry in !! Made sense to me.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    It's not an error to turn the SWG off during a SLAM. I always recommend turning it off or leave it up to the OP to turn it off or leave it on. I don't see it makes a huge difference in how bleach is saved. 😎
    Jeff
  20. Back To Top    #20
    aussieta's Avatar
    Jan 2014
    Langwarrin, Victoria, Australia
    488
    before adding bleach
    i would be testing the return water from the jets for chlorine content as op cell may have failed
    hate to slam and then find cell is faulty and have to slam again
    being in florida i assume your water temp is over 55f
    SWG inground peanut shaped eco-bright concrete pool
    50,000 litres 13,000 gallons
    Lincoln Salt Chlorinator, 25 gram cell Sand Filter with glass media
    Taylor K2006-C test kit, Taylor K-1766 salt test, Dolphin M500 pool cleaner
    are you taking care of your pool or is the poolshop taking care of you
