Thread: PSI - Closing
    Oct 2011
    Chicago, IL
    113
    PSI - Closing
    What PSI level is it safe to blow out lines on pool for an aircompressor? I have one of those portable units with a regulator. Thanks!
    I have a 35,000 gallon, sand filter, sunken above ground (so inground), vinyl liner, with an Aqua rite turbo cell SWG
    New Brunswick Canada
    819
    Re: PSI - Closing
    No more then 25PSI.
    Oct 2011
    Chicago, IL
    113
    Re: PSI - Closing
    one more question - how do i get the anti freeze in the lines after i blow out the lines (not main drain) with the aircompressor?
    819
    Re: PSI - Closing
    once they are clear of water, you can then remove your attachment and pour in antifreeze, reconnect and just give it a short blast to move that antifreeze to a low spot, that is where any water will go and this helps protect from freezing.
