Page 1 of 5 1234 ... LastLast
Results 1 to 20 of 87
Thread: Geometric Houston pool
    Aug 2013
    Houston, Tx
    94
    Hi guys, I'm a little late to the game starting this thread. Our pool got rebar today, but I figure it's never too late to chronicle the progress. Here are the details:
    Width 19'
    Length 34'
    Depth 3 1/2-7 feet
    Perimeter 109 LF
    Pool Area 615 sq ft
    Approx gallons: 20756
    Pool Shape: Rectangle with spa
    Coping: travertine
    Color: TBD
    Tile: We will fit the interior 6" water line of the pool and/or spa with the following frost-proof tile: Main tile choice, std
    Interior finish: Wet Edge Pearl or Satin
    Steps: We will build 3 concrete steps into the pool
    Extended bench: 28 linear feet
    Raised bond beam:
    16 ft of 12" bond beam
    15 ft of 18" bond beam
    8 ft of 24" bond beam - columns
    Sunshelf: 14 ft wide at the pool beam approx. 98 sq ft to a depth of 8"
    Swim Out/Deep end: We will install a built-in swim out 4 ft long per plan
    Pool Equipment Features:
    Filter system: 430 sq ft cartridge pool filter
    All plumbing for pool included with filtration equipment within 50 ft of pool
    Pool pump: 2.7 HP Variable speed
    Air blower: 1.5 HP Polaris QT blower
    Electronic controls: PS-8 wireless with aqua connect
    Sanitation equipment: Hayward salt system
    Heater: Natural Gas 400,000 btu
    Pool Cleaner: PV-3 infloor
    Lighting equipment: 2 LED
    Return lines: 6
    Water fill line: auto
    Bubblers: 3 std
    Other water features: 3 natural scuppers with booster pump
    2 concrete water 30" bowls with fire
    Spa: 50 sq ft of water surface
    All plumbing for pool filtration equipment within 10 ft of spa
    Jets: 8
    Lights: 2 LED
    Raised spa facing: raised 18"
    Pool side type: tile
    Outside type: ledgerstone
    Mechanical specifications:
    Skimmers: 2 Hayward
    Pool returns: 4 1.5" Schedule 40 PVC
    Pool main drains: 2 anti-entrapment, VGB compliant
    Spa main drains: 2 anti-entrapment, VGB compliant
    Deck, electric, and gas
    Deck: 1330 sq ft
    Deck material: stamped concrete with Shark Grip
    3 sleeves inc.
    Area drains: 6
    Linear drains: linear ft each drain 75 with overflow
    Other: One 4 ft H x 18" W gas fire pit with manual light
    Electrical work: We will install electrical conduit and wiring from your existing electrical panel to your pool equipment. This includes permits, inspections and hook-ups for lights, booster pump, filter pump, air blower, heater, electronic control, and 2 remote J boxes.
    Natural Gas Plumbing:
    We will install up to 45 ft of gas line from your existing gas meter to pool heater.
    21k gal IG, SWG, WetEdge Satin Matrix Antigua in pool, Primera Stone Tahoe Coast in spa, 430 sq ft cartridge filter, 2.7 HP variable speed pump, infloor cleaner
    Our build:
    http://www.troublefreepool.com/threa...c-Houston-pool
    Aug 2013
    Houston, Tx
    94
    And pictures
    Anyone know what this is?
    Our build:
    Aug 2013
    Houston, Tx
    94
    Re: Geometric Houston pool
    So I already caught an omission - the spa has 7 pipes for jets, when we asked for 8. PB is going to come out tomorrow to take a look. Let me know if you pick up on anything else. Our PB is going out of town for 2 weeks this Friday and while he has a substitute, I don't know him from Adam so I feel like I need to get everything straight before he leaves.
    Guess I need to change my signature now...
    Our build:
    Jun 2014
    Sanger, TX
    555
    I am a big fan of the geometric pool shape. Look forward to watching your build progress - Karen
    New in 2017, will update
    Beadedbiker's Avatar
    May 2013
    New Iberia, LA
    276
    I am also a geometric fan. Looking good so far.
    Eva.
    We are building a 14x28 in ground with a spillover spa...
    All Pentair Equipment, 3HP VS pump, Sand Filter, 250K BTU gas heater, 2HP blower.
    Easytouch 4. Pentair Racer Cleaner.
    swoopman's Avatar
    Jul 2014
    Annapolis, MD
    213
    Looking good. Thanks for sharing the pics.
    "Anyone know what this is?" = Skimmer
    TF-100 Test Kit
    22,000 gallon, 20x40 kidney-shape IG plaster pool built in 1986
    Nautilus NS-36 DE filter, Hayward Self Prime Super Pump 1HP
    Polaris Automatic Pool Cleaner, PB4-60 3/4 HP pump
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    That looks really nice! What are the 4 wall intakes in the deep end for?
    Sep 2014
    Wharton County, Texas
    32
    Can I ask who your PB is?
    19K gallon free-formed w/ 60% Color Quartz plaster
    3.5' x 5.5' x 4' depths - 15' x 20' 15' widths - 12" oval raised spa with spillover
    Hayward 1.85 hp TriStar VS Pool & 1.25 hp water feature pump - Cartridge Filter
    Hayward OnCommand automation system - 400K BTU heater - LED lights for pool & spa
    20' weeping moss rock wall - 5' x 8' tanning ledge with bubbler
    Aug 2013
    Houston, Tx
    94
    Thanks for the compliments. It is exciting to finally have it underway after researching for so long. I was fully prepared for total destruction when it was time for plumbing, but it wasn't too bad. When we were building our house, we told the builder not to finish the backyard at all, knowing we would start this pool as soon as we closed. So maybe it helped having less to destroy.
    Quote Originally Posted by Melt In The Sun View Post
    Thanks! Can you repost the pic you're talking about? I don't know intakes from skimmers at this point, lol.
    Swoopman, thanks. Definitely a steep learning curve here.
    Oct 2009
    3,899
    The four circles on the opposite wall in this photo!
    Glock's Avatar
    Jun 2012
    Mesquite, Texas
    866
    I was curious about those as well.
    18x34 Doughboy AGP 22300K Gallons - Build Thread
    Aquaview 24" Sand Filter - 1.5 HP Powerline Pump - Barracuda Ranger - Taylor K-2006 - BBB
    Pool School and Pool Calculator
    Aug 2013
    Houston, Tx
    94
    Wonder if it has something to do with the infloor cleaner?
    Apr 2014
    NE Texas
    327
    Maybe its the intake for the booster pump for the scuppers?
    Done! Pool build thread here
    38 x 18 free form, IG gunite with all gunite waterfall/slide/grotto
    18" raised spa, waterfall into pool
    Hayward 3hp Tri Star Pump x 3, 525sqft Swimclear filter, Polaris 280 cleaner
    Hayward LED pool lights, Hayward LED accent lights, 400K BTU Heater
    Aug 2013
    Houston, Tx
    94
    Gunite happened today. PB added the additional spa jet the day before so I think we are squared away there. He said we need to water the gunite a couple times a day. Does everything look ok?
    Our build:
    Aug 2013
    Houston, Tx
    94
    Left one out. It's got a good view of the guts so I figured that's important.
    Our build:
    Glock's Avatar
    Jun 2012
    Mesquite, Texas
    866
    Uhmm.. I found a fatal flaw. Mind you its easily fixed but could potentially double the cost of the pool if not done properly. If you look very closely all over the pool you will see that it's clearly NOT IN MY BACKYARD! FIX THAT POST HASTE! Hahaha!! Looks good. I can't wait to see it finished!
    Aug 2014
    Haslet, TX
    29
    With all of the pictures you posted I do not see a bonding wire. Did they add this before the gunite? Looks good so far!
    Aug 2013
    Houston, Tx
    94
    Oh my gosh Glock, you had me going for a minute there. Glad the fatal flaw is fixable, lol.
    Erik what is a bonding wire? Not sure what that is or what to look for. Let me know and I will look thru my pictures.
    May 2013
    New Iberia, LA
    276
    If it passed inspection prior to gunite it had a bonding wire. None of the pics posted are high enough resolution to pick out a #8 copper wire, no closeups of the light niches either.
    I like your design a lot. Might have stolen it if I'd seen it before I designed mine!
    Eva.
  20. Back To Top    #20
    Jun 2014
    Sanger, TX
    555
    Quote Originally Posted by aprillh View Post
    Ha Ha, I agree - At first I thought Glock and Pool Critic got together and I kept reading to see what the issue was....Glock is being funny on lots of posts today
    EVA - This question was a total set up / lead in for you.....Actually April's design and yours remind me a lot of each others. Very simple and clean - and like cc's - which makes your eye really pay attention to the detail.
    -Karen
