Results 1 to 7 of 7
Thread: small rust hole
    small rust hole
    I have a small rust hole in my pool about a quarter of an inch across. Is there any way of repairing it that does not have me draining the pool.
    14500 gallon AG Sand Filter 2010
    Glock's Avatar
    Jun 2012
    Mesquite, Texas
    866
    Re: small rust hole
    Do you have a pic? Do you know what caused it? Rust hole in a vinyl liner is easily patched without draining the pool but I would make sure whatever caused it is gone first. Any local pool store should have patch kits available.
    http://www.intheswim.com/Pool-Liners...ner-Patch-Kit/
    18x34 Doughboy AGP 22300K Gallons - Build Thread
    Aquaview 24" Sand Filter - 1.5 HP Powerline Pump - Barracuda Ranger - Taylor K-2006 - BBB
    Pool School and Pool Calculator
    Re: small rust hole
    Thank you for helping me. I think the original rust probably started from a stone chipping the surface of the pool. the liner doesn't seem to be leaking at this point I just need to repair the hole in the aluminum side. The hole is about the size of a pencil.
    Glock's Avatar
    Jun 2012
    Mesquite, Texas
    866
    Re: small rust hole
    Oh you mean the side wall is rusting from a hole that is in it? Can you post a pic?
    Re: small rust hole
    Quote Originally Posted by Glock View Post
    I can but I'm away right now so it will be a couple of days before I can post a picture.
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    Re: small rust hole
    How far down the side? Most of the time you need to drain down below the hole so you can slip a piece of metal flashing in and duct tape it in place. The tape protects the liner from the sharp edges and the water presses the plate against the wall.
    Dan D
    Used 2003 Aqua Leader 27'x52", 17,800 w/10" hopper, SwimPro SW256T 250# sand filter, Hayward PowerFlo LX pump 1hp impellor, Emerson 1 1/2 hp motor, setup Aug 2012 Summer 2011 used Summer Escapes Ring pool 14' x 42", Intex 1600gph sand filter, HTH 6 way test kitTF-100 w/stirrer, Well water @ FC=0, PH=7.2, TA=290, CH=320
    Glock's Avatar
    Jun 2012
    Mesquite, Texas
    866
    Re: small rust hole
    I agree with msgtdan. You might even want to consider cleaning the rust up and applying a rust inhibitor and patching both sides to make it last longer. Depending on where its located that is.
