Thread: Are there any valve actuator that can be programmed without pool automation system?
    Aug 2014
    Allen, TX
    67
    Are any of the pool actuators that can be set to let's say run 2 hours when pump is on, but that do not require fancy automation system to be set up?
    10K gallons, IG vinyl free form Radiant Pool, 1HP SuperFlo 2 speed pump, 175 sqft Hayward C17502 plus cartridge filter, Intex Krystal Clear Saltwater System CS8110 Model 54601EG, Jandy Pro Series Underwater Nicheless LED. 1 skimmer, 1 suction outlet, 3 returns, The Pool Cleaner. Pool installation in progress as of 09/24/2014.
    38,475
    Re: Are there any valve actuator that can be programmed without pool automation syste
    They are very basic controls. Supply 24v power to one wire and they turn one way until they hit a stop. Supply power to the other wire and they turn the other way until they hit the cam stop.
    So if you can rig up 24v power and a timer to switch where the power is sent then you would have control.
    Aug 2014
    Allen, TX
    67
    Ok, cool. One can adjust the cam stop position?
    38,475
    Yes. It is inside the actuator. You adjust a cam which hits an electrical switch to stop the rotation.
    Jul 2014
    Haslet, TX
    19
    It's 24VAC. Check out page 11 of this manual for some writing suggestions: http://www.southshoregunitepools.com.../JVAmanual.pdf
    23K gal, 38' x 22' irregular, gunite, StoneScapes Mini Pebbles, 2 HP TriStar 2spd pump, 525 sqft cartridge filter, TurboCell SWG, ProLogic controller, The Pool Cleaner 2 Wheel
