Results 1 to 9 of 9
Thread: Heat Pump Water
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    Heat Pump Water
    I gather when running there should be water coming out the bottom, or is it a leak?
    13,000 Gal Pool & Spa
    Jandy Automation /w IAqualink
    Autopilot SWG
    Jandy 2.0 HP VSP, Filter Cartridge
    Taylor (FAS-DPD K-2600, Pool Surface: Plaster
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Re: Heat Pump Water
    sounds like a leak.
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    Re: Heat Pump Water
    Would it leak when just the pump running also, and the heater not on? Doesnt water still circulate through the heat pump?
    Autopilot SWG
    Apr 2011
    Murrieta, CA
    2,360
    Re: Heat Pump Water
    Sorry. If there is water coming from the bottom only when the heat pump is running it could be sweating. If the heat pump is off and the pump is running and there is no water then all is well.
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    Re: Heat Pump Water
    Ya i tester the water no chlorine in it.
    Autopilot SWG
    Apr 2011
    Murrieta, CA
    2,360
    Re: Heat Pump Water
    What kind of heat pump?
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    Re: Heat Pump Water
    Jandy titan
    Autopilot SWG
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    Re: Heat Pump Water
    There's plenty of humidity out here.
    Autopilot SWG
    Apr 2011
    Murrieta, CA
    2,360
    Re: Heat Pump Water
    Yeap. I'm in Lakeland, FL. I know the humidity.
    Here's the link to the manual (not sure if your particular model): http://www.fwpb2b.com/customer/docs/...ump_manual.pdf
    and from the trouble shooting section:
    Heat pump leaking water.
    Possible heat exchanger or plumbing leak. Turn the heat pump off, then turn circulating pump off for at least one hour to see if the water leak stops. If the water leak stops, normal condensation is occurring. If the water leak continues, after heat pump is shut off for at least one hour, call for service.
    Hope the info helps.
