Thread: Infrared alarms
    Jul 2012
    Walpole, MA
    23
    Infrared alarms
    Does anyone know of or have experience with an infrared alarm. Thinking of something that would stand at each corner of your pool deck and emit an infrared beam that when broken would sound the alarm?
    18ft/40ft, 29,600 Gallons, Vinyl Liner, Hayward Perflex Extended Cycle DE Filter, Hayward Super Pump (HP1), Hayward CL220 Chlorinator
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: Infrared alamrs?
    It is an alarm industry product. Something like this.
    Usually it is tied into a an alarm system but someone could probably come up with another way to control it.
    I have PE beams in a large garage I keep my camper in. They will trip from almost any object crossing the beam. In an exterior application I would assume that insects getting inside and crawling across the sensor would look like elephants dancing on the pool deck to the sensor.
    Support the site
    ps0303's Avatar
    Jul 2011
    FL
    3,695
    Sounds interesting. We all probably have the infrared things on our garage doors and I can tell you that on mine sometimes in the morning the sun hits it just right and the door won't close because the beam is not connecting to the other side due to the sun light. Could be an issue sometimes outside.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Paul, sounds like you need to cut open an aluminum can and make a little shield around your sensor to shield it from sunlight coming in.
    Another way to do the pool would be to use motion sensor lights as their sensitivity is usually adjustable. You wouldn't necessarily need the lights but can use the sensor to trip the alarm in conjunction with the lights or in place of them. When the sensor trips you'd have power on the neutral side of the sensor and can use that to power a 120 volt alarm of some sort.
    Solar Blanket, Well Water, Borax Added. 68
