Shotcrete day is an exiting one. My pool is shotcrete and I still watered it. the curing process generates heat and keeping it moist reduces cracks from dehydration. If you walk in the pool now you'll feel the heat coming off it.
Is that a step in your spa? If so, what a great idea. - Karen
Just out of curiosity, do the pines by you develop deep taproots? If so, did the excavation crew have to dig really deep to get it out, or was the trunk not in the way of the pool dig area? I have taken down about 4 mature longleafs in my yard, ranging from 16-18'' in diameter. I have another 16'' one that will have to go when I do my pool build, it is in the way of where the screen enclosure footer will go. I still have about a dozen more, they are so common in the part of FL I am in.
Talking to pool builders, one told me that he had to excavate 16' down to pull a pine taproot out of where the pool was going to go. He then backfilled with gravel to the appropriate depth the pool pit needed to be.
Shotcrete is fully mixed (premix) wet concerete applied as a spray. Gunite is a "dry" mixture that has water injected at the gun during application. Applied properly, there is no significant difference in the end result of the two different mixes. As you correctly noted, gunite needs to be kept moist as it cures whereas shotcrete was applied wet and cures as it dries.
Just curious if this was told to you by the shotcrete company?
Wow! That looks incredible! What color interior is that?
