Results 1 to 9 of 9
Thread: Ebay cya
    May 2014
    Dfw
    29
    14k gallon, vinyl in ground, 1 hp pentaire pump, pentaire sand filter, taylor k2006 kit,hayward shark vac cleaner, pool blaster cg vacuum
    38,475
    Re: Ebay cya
    That is pretty expensive for only 2 pounds ... cheaper at Walmart.
    Oct 2013
    Chapin, SC
    1,141
    Re: Ebay cya
    Especially if your local walmart has My Salt Pool Saltwater Stabilizer, 6.5 lb at around $20. You'll need to do a Google search to see where else you may find it locally.
    Pool size: 24000gal inground Vinyl-Taylor k-2006 and k-1766 test kits and-speed stir
    Intermatic P1353ME digital timer w/freeze sensor
    CircuPool Si-45 SWCG System
    Polaris 280 vacuum/Polaris PB4-60 boost pump
    Pentair IntelliFlo VS 3hp Pump--Pentair sand filter
    Jul 2014
    Hope Mills, NC
    567
    Re: Ebay cya
    Ebay is for chumps anymore...
    16 x 32 17500 gallons
    Vinyl in-ground
    Hayward 250# Sand Filter
    1 HP Pump
    Hayward SWG
    Aug 2010
    Dallas, TX
    4,052
    Re: Ebay cya
    Unless you are buying boric acid from Duda Diesel. For some reason they charge a whole lot less on shipping when you buy from them on eBay than if you buy from them directly.
    38,475
    Re: Ebay cya
    I thought I found the shipped price to be basically the same between Ebay and DD ... although I also found it cheaper to get two 25 pound bags instead of the 55 pound bucket which had much higher shipping.
    Aug 2010
    Dallas, TX
    4,052
    Re: Ebay cya
    There was a $50 difference on my recent shipment, even including the fact the price for the product is slightly higher on eBay. But I was buying 165 lbs, maybe that's why.
    May 2014
    Dfw
    29
    Re: Ebay cya
    This stuff suitable?
    http://t.homedepot.com/p/HTH-4-lb-St...1316/100239944
    Oct 2013
    Chapin, SC
    1,141
    Re: Ebay cya
    Yup unless you can find this nearby: http://www.walmart.com/msharbor/ip/M....5-lb/34752155 if not walmart, try Kmart. Try googling it for local availability.
